Toilet flange is level w/ finished tile floor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JeffV, Jun 25, 2007.
  1. JeffV
    JeffV New Member
    Mar 16, 2005
    and not sitting on top of it as it should. Will a normal wax ring fail to seal in this situation (its only 1/4" off), and if so which is the best way to deal w/ this:
    1. Stack 2 wax rings
    2. Use an extra thick wax ring
    3. Use a pvc flange extender
    Also, are the wax rings w/ plastic horns bad news?
    Thanks for any suggestions - Jeff
  2. jadnashua
    Most of the pros would use two wax rings from what I read. ME, I'd consider that or a waxless ring...they have a horn built in. The combination of wax and a ring can be problematic, and since the plastic doesn't seal well if it slips a little because then the wax can't make the seal, yes, they can be a problem. Probablhy for other reasons as well.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    For 1/4" I'd just go with the thicker wax ring. If you can feel it squishing down when you seat the base of the toilet, you're in business. If you feel like you've bottomed out, use one of the other techniques you mentioned.
    I personally only use the horned wax ring and have never had a leak. If nothing else, they are easier on the next guy, because they generally come off in one piece with minimal scraping. And who doesn't hate scraping that nasty germy wax.;)
Similar Threads: Toilet flange
Plumbing Forum, Professional & DIY Advice Toilet flange too high? Thursday at 7:18 PM
Plumbing Forum, Professional & DIY Advice Replace Toilet Flange? Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Help with toilet flange Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Toilet Flange Install Question Dec 29, 2016
