LarryM13
Ready to install my toilet flange in my basement bath (tiled over concrete)
I have a 3" PVC pipe sticking out of the ground and am installing a 4" PVC toilet flange over the 3"
I've been reading around a bit, besides wishing I went with a 4" PVC coming out of the ground so I can slide a 3" inside, I seem to be noticing differing opinions on: primer and glue or just glue for flange connections.
I can see a 3" flange going inside a 4" pipe as maybe not needing the primer as waste/water won't be exposed to the seam between the 3" flange and 4" pipe, but what about the 4" flange going over the 3" pipe?
I would assume in my situation, primer and glue to weld that seam to not let any waste/water get through is the appropriate method?
Praying this flange doesn't break, primer/glue would be a nightmare to repair.
Larry
Larry
