Toilet flange in lead drain sleeve
Discussion in 'Toilet Forum discussions' started by do it right, Mar 31, 2008.
  1. do it right
    do it right New Member
    Mar 10, 2008
    Dallas, TX
    Just remodeled and re-tiled our bathroom. There were two layers of tile on a mud bed which was with plywood and hardibacker and new tile. As a result, the floor is much lower than the toilet flange - 3/4". The flange was made of brass and was soldered to a lead sleeve that runs straight into a cast iron fitting below - it does not bend (the sleeve is about 5+ degrees off of plumb).
    Can someone provide a recommendation for how to approach my problem? It seems like keeping the lead and soldering to a new brass flange would be best since the cast iron fitting is a tad offset from the flange. Are there other options?
    Thanks,
    James
Similar Threads: Toilet flange
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
Toilet Forum discussions Odd Offset Toilet Flange Dec 21, 2016
Toilet Forum discussions Toilet Flange Height on New Tile Dec 19, 2016
Toilet Forum discussions Toilet flange question Dec 7, 2016
Toilet Forum discussions How do I Install Toilet Flange to Stubbed Pipe in Concrete Slab Nov 20, 2016
