Toilet Drips and makes Ice Blockage in Main Drain
Discussion in 'Toilet Forum discussions' started by molo, Mar 4, 2010.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    I believe the toilet is dripping into the main line and if it's out of use for a couple of days when it is cold outside it is forming an ice blockage in the main line.
    What steps can I take to stop this from happening?
    I'm wondering if it's being used as the expansion tank for the water heater. However, there is no backflow preventer into the municipal water system (not required here) so I'm wondering if the system would need the toilet for expansion.
    Over a few cold days it froze a 4" line completely solid (in the basement).
    Where do I start?
    Thank you,
    Bill
  2. jadnashua
    Is the flush valve leaking and water is going over the overflow tube or is it leaking by the flapper? Shut the water off and see if the tank empties, if it's not going down the overflow.
  4. molo
    molo Member
    Sep 23, 2006
    Cold New York
    I'll check that out, thanks Jad.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Are you on septic or city sewer? Either way there should be enough heat in the line to prevent freezing. The only time I saw this happen is when the septic tank was pumped when the temperatures were below freezing.
    John
  6. molo
    molo Member
    Sep 23, 2006
    Cold New York
    This is septic, but I've heard of it on city when the line wasn't deep enough outside and ran under a driveway where the frost was driven down.
  7. Beads
    Beads All thumbs
    Mar 3, 2010
    biologist
    New Orleans
    Why is your basement so cold, are some walls exposed? Are your floors insulated? You must have other pipes there too. What keeps them from freezing?
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    A leaking toilet can indeed cause a ice blockage to form in the main line.
    For that matter so can dripping faucets and bellies in the line...
    There are many drain lines that are not buried below the frost line that work great unless one of the above problems exist.
  9. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The 4" line froze at a place where an elbow is right up against the rim joist and there is no insulation. I need to find the drip.
Similar Threads: Toilet Drips
Toilet Forum discussions Toilet Bowl Drips water back down into sewer pipe Nov 20, 2013
Toilet Forum discussions Sterling Toilet Drips Into Bowl W/New Flapper Jan 5, 2011
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Saturday at 9:53 AM
Toilet Forum discussions Icera wall-hung toilet Saturday at 8:36 AM
Toilet Forum discussions Toto toilet seat hinge cover Friday at 4:53 PM
