Jeremytl
Scientist
The bolt has a slight drip on one side. It appears to be where the tank bolts to the seat piece. When I tighten it, the drip increases to a steady drip. When I loosen it, it slows, then if I loosen it farther, it increases to a steady drip again. Is there a seal in there that could be bad. Do I have to empty tank and unbolt/ lift up off of throne and simply replace seal or does this appear to more a more complicated issue. Thanks in advance
