toilet drain vertical minimum
Discussion in 'Toilet Forum discussions' started by glebbscout, Nov 23, 2006.
  1. glebbscout
    glebbscout New Member
    Nov 23, 2006
    What is the minimum vertical height between the bottom of where the bend starts in the horizontal drain pipe and the flange? Assume the drain pipe is 4" interior dimension and flange is 1/4". The center of the drain pipe is only about 18 inches from vent stack so not a lot of slope to it.
    Diagram:
    _ (flange sitting on floor)
    min. vertical? l
    ________ (horizontal pipe line)
    Thanks.
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    It wouldn't be too hard to lay a closet bend against a flange in any of the big box stores to get a rough idea. I'd guess something like 6-7".
  4. glebbscout
    Nov 23, 2006
    yes, but...
    I guess what I mean is: is it acceptable from a plumbing perspective to have such a short distance for the water etc. to flow from the toilet, into the drain before it hits the bend? If the flange measures 2 inches, roughly, top to bottom, plus the 4 inches until the bottom of the pipe, that's not much of a drop before it hits the bend. Does that matter?
  5. hj
    height
    The minimum distance is as little as you can cut it and still get the flange to slide over with a good seal. Which usually means the riser has to be as long as the flange is deep.
Similar Threads: toilet drain
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Saturday at 9:53 AM
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions 180 degree turn on 3" toilet drain Sep 12, 2016
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
