Toilet drain / vent for new bathroom
Discussion in 'Toilet Forum discussions' started by jeff_bathroom, May 14, 2006.
  1. jeff_bathroom
    jeff_bathroom Member
    Dec 15, 2005
    Florida
    Hi,
    I've attached a photo of my proposed drain / vent for the toilet. The
    pipes shown are not glued yet. I wanted to be sure this configuration is ok for code and whatnot.
    What the photo is showing from top down is the flange, then a 45 degree elbow, then about 24" of 3" pipe connecting to a 3x2 Y to vent. I could not vent behind the toilet due to electrical panel behind the toilet wall, so I'm venting up the wall adjacent and next to the toilet.
    Can anyone tell me if this is ok to go with ?
  2. Terry
    Aug 17, 2004
    That would work in Washington State for a toilet vent.
  4. jeff_bathroom
    Dec 15, 2005
    Florida
    Are you saying it's a bad setup? Can you please
    help a little more w/ details? Thanks.
  5. NaumoffPlumbing
    NaumoffPlumbing Plumbing heating and cooling contractor
    May 15, 2006
    Prince Frederick, MD
    Where are you located? Are you getting the job inspected?
    It will work. Different areas have stricter codes then some.
    Terry, I am a new guy so I hope I am not stepping on your toes. :)
  6. Terry
    Aug 17, 2004
    Not stepping at all.
    The reason I even mention codes and location, is inspectors being who they are, and how large this country is, there will always be some differences.
    What I see are nice wye fittings and 45 els. It looks nice.
    The toilet is one of the few fixtuers that can be vented this way.
  7. jeff_bathroom
    Dec 15, 2005
    Florida
    Hi Naumoff,
    I'm in GA. I really appreciate your response. I'm sort of getting the impression that coming straight off the flange at 45 degrees for several feet then venting is a little peculiar. I've seen pictures similar to this in one of my plumbing books.
    I am considering changing this setup so that the drain pipe goes down
    vertically from the flange to just below the joists (about 8.5 inches) then doing a 90 degree and heading directly under the 2" vent pipe connecting to it and the 3" drain using a 3x3x2 combo. I suppose that would be more normal
    than what I have in the photo. But, I don't know how far below the flange I'm "allowed" to go before the 90 degree turn. I need to be below the joists.
    The thing that plumbing books don't talk much about is whether it's ok to run drain pipe at various angles that are not the usual vertical or horizontal with the proper slope per pipe diameter. I know there's issues with fluid speed at different angles, but not much more than that.
    Suggestions welcome ! Thanks again... :)
  8. jeff_bathroom
    Dec 15, 2005
    Florida
    Question about toilet flange
    Hi,
    reading my various plumbing books related to toilet connections, I usually see a "closet bend or closet flange" which is a 4" flange with a gradual reduction to 3" diameter. However, I have yet to see one of those in Lowes or Home Depot. Instead I see a short 4" flange with an immediate reduction to 3" such that you connect to a 3" pipe from that small flange. I'm assuming that's the preferred method these days over a closet bend. Is that so?
    I am still wrestling with this connection because immediately below is a cinderblock wall that is in the way by a little over an inch. What I'd like to do is come off of the flange with an 1/8 bend, then down an inch or so and add another 1/8 bend in the opposite direction to bring back to vertical and get around the cinderblock.
    Is that an acceptable/practical/in-code toilet connection ?
  9. hj
    toilet
    The reason the closet bend into the tee is "normal" is that it is the way most plumbers would do it. But that does not make it more "right" than your way. The "right" way for any installation is the one that is best for that particular set of circumstances. Unless the inspector has some particular reason for not liking it, your way is perfectly okay. I might have come straight down from the toilet flange into a Y for the vent before offsetting it to the drain connection, but that does not make it any better than your design. If would just have used fewer fittings.
  10. jeff_bathroom
    Dec 15, 2005
    Florida
    thx
    Thanks hj,
    I appeciate your help. I'll tape these together again and post
    another photo and see if it looks ok.
  11. jeff_bathroom
    Dec 15, 2005
    Florida
    Different Toilet Drain config...
    Hi,
    I've changed the drain/vent config. What say ye ?
    Look better ?
  12. Terry
    Aug 17, 2004
    Frankly, I like the old picture better.
    The new picture would not fly where I plumb.
    The 3x2 santee would need to be replaced with a 3x2 wye or combo fitting.
  13. hj
    vent
    The system is cleaner that way, just replace the tee with a combination Y-1/8 bend and you should be home free.
  14. jeff_bathroom
    Dec 15, 2005
    Florida
    Thanks for the look...
    Terry,
    I thought w/ my old config that the 2 foot long 45 degree drain pipe
    was sort of a no-no, which is why I went to this new configuration.
    HJ,
    I think I know what a Y-1/8 bend is, but I'll need to look it up to be sure.
    Not sure why though that the existing T is an issue. I wondered about the sanitary T; but I thought it was more that you had to have a sanitary T for the drain line rather than it being an issue used in a vent. Thought wrong, I guess.
    Thanks again guys. I'm almost ready to kick this project into gear.
  15. jeff_bathroom
    Dec 15, 2005
    Florida
    Y 1/8 bend
    Is that the piece I have in my first photo ?
  16. hj
    y
    That fitting with a street 45 would be equivalent to the combination, just two pieces instead of one.
  17. jeff_bathroom
    Dec 15, 2005
    Florida
    This got it?
    Hi Terry/HJ,
    I think I've done your bidding. How does the Y w/ 45 look now for vent?
    I've also attached a photo of where this 3" drain connects
    to the main 3" drain running the length of the house. Does that
    Y look ok to connect? I had planned on cutting two short pieces on
    either end and connecting with those screw-tight rubber connectors.
    I originally bought an all rubber Y, but the angle of its Y is not right and
    I didn't like how the inside diameter looks smaller to me than regular 3" pipe.
  18. Cass
    Cass Plumber
    Nov 12, 2005
    Looks fine to me.
  19. jeff_bathroom
    Dec 15, 2005
    Florida
    Thanks Cass.
    Is the Y w/ rubber connectors to the main drain ok?
  20. Terry
    Aug 17, 2004
    [​IMG]
    You will want to go with a metal sleeved coupling.
    They call these shielded no-hub couplings.
    The metal shielding prevents the pipes from shifting over time.
  21. jeff_bathroom
    Dec 15, 2005
    Florida
    Thanks Terry;
    I'll return the rubber ones w/ metal straps and pick up some of those.
    I really appreciate the good advice; thanks again.
    More pics coming of addition of utility sink drain and vent.
Similar Threads: Toilet drain
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Feb 25, 2017
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions 180 degree turn on 3" toilet drain Sep 12, 2016
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
