I moved my toilet to the left 3'. In doing so i increased after the 3" abs Y that go down to a 4" abs pipe with one added 90 degree while keeping entire pipe slopped downhill. Question is will the increase from 3" to 4" using a adaptor coupling that smooths threw ( not a reducer that stops flat to reduce ) be a problem? And does adding a 90 hurt my flow? I am installing a pressure toilet. If so what should I do?
