Toilet Drain PVC Pipe Size
Discussion in 'Toilet Forum discussions' started by Oscar15, Jan 24, 2005.
  1. Oscar15
    Oscar15 New Member
    Jan 24, 2005
    I am currently in the process of moving the existing rough in toilet drain pipe in my basement. I need to move the toilet 12” to the left. I have rented a jack hammer and I have removed the concrete and gravel and I have exposed the 3" drain pipe. The pipe originally went from a 3” to 4” using 90 degree and that left a 4 “pipe exposed in the floor. When connecting a new 90 degree and a 45 do I have to go back with a 4 inch pipe to the flange or can I use all 3”. What is the purpose of the 4” section of PVC PIPE?”
    [​IMG]
  2. hj
    4"
    It is called a 4" x 3" closet bend and is the only way I ever rough in a toilet. Many use 3" pipes with no problems. So it is up to you.
Similar Threads: Toilet Drain
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Feb 25, 2017
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions 180 degree turn on 3" toilet drain Sep 12, 2016
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
