Toilet drain line carry question
Discussion in 'Toilet Forum discussions' started by Mad Plumber, Jan 14, 2008.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    Greetings,
    I had a question pertaining to a repeated plugging of toilets on the basement level. The toilets drain pipe runs horizontally 40 feet or so before entering the city sewage system. Do low flow toilets with 1.6 L flow flush have enough water pushing human waste this distance and subsequently, will repeated similar events lead to a plugged / blocked drain line?.... Furthermore, could this be a toilet paper problem... are some brands better than others in preventing clogs in that they break down or shed and disolve quickly once in contact with water.
    Can you shed some light on this issue and recommend a toilet (or paper) that would address my concerns... or are these thoughts unfounded.
    Cheers, Graham H.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    What is the specific problem that is occurring? Is the line clogging, or, are the toilets clogging?
  4. jadnashua
    If the pipe is installed with the proper slope and doesn't have any low spots or roots intruding, it should work fine. Older cast iron could get rougher inside - pvc or abs stays smoother and flows better.
  5. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    sometimes the plastic pipe gets bowed down when they pour the concrete floor. this creates a slight hill to go up making obstruction of the pipe more likely. throw in the water saver toilet and some teenage girls using two-ply toilet paper and whatever else they might use and you have a recipe for disaster. :(:rolleyes:
    seems i've seen the scott one-ply paper recommended more than once here.
  6. Terry
    Aug 17, 2004
    Many 1.6 gallon toilets will have a drain line carry of about 58 feet.
    Hiowever, I think they go farther than that with smooth pipe.
    The last place I lived, it was 250 feet to the main sewer.
    If you need to push it though. Something with a 3" flush valve, or even better would be to push it with a pressure assist from Flushmate. Kohler makes a nice bowl that you can get with a Flushmate.
    [video=youtube_share;Rrcuvd2vV6o]http://youtu.be/Rrcuvd2vV6o[/video]
Similar Threads: Toilet drain
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions 180 degree turn on 3" toilet drain Sep 12, 2016
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Weird toilet sewer drain help??? Jul 26, 2016
