Toilet drain clearance
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rcoatsie, Oct 3, 2011.
  1. rcoatsie
    rcoatsie New Member
    Oct 3, 2011
    RI
    Hello, ..... I am going to install a toilet above a concrete slab, and run the drain over to the cellar (about 5' of run). I have about 9.5" of space between the bottom of the toilet and the concrete slab. Should I have enough clearance for the correct drain slope ?? I can shorten the 5' run if I have to.
    Thanks ........ Robin
  2. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    Are you saying that you are putting the toilet on a platform (2x10 joists)? I wonder since you say "I have about 9.5" of space between the bottom of the toilet and the concrete slab."
    Typically, you figure a slope of 1/4" per ft. You won't have the full 9.5" to work with as there needs to be room for the closet bend/elbow below the toilet.
    Please provide some additional details of the install so we can get a better idea of what you are actually dealing with.
  4. Terry
    Aug 17, 2004
    You have plenty of space within a 2x10 joist space. The drain will be 1/4" per foot, or 1" in four feet.
  5. rcoatsie
    rcoatsie New Member
    Oct 3, 2011
    RI
    Thanks for the reply. The slab area was part of an attached garage. It is a raised area now, but after we get this bathroom figured out, we are going to be pouring more concrete (radiant floor) around this area. They are 2x8 joists, that have been shimmed off the concrete with some pressure treated wood, so yes basically 2x10s. The bend elbow depth dimension is what I need, along with the 1/4" per ft ??
  6. nukeman
    Nov 20, 2009
    Nuclear Engineer
    VA
    Correct, but it sounds like you have plenty of room. You'll only need about 1.25" of slope over that 5', so you have plenty of room.
Similar Threads: Toilet drain
Plumbing Forum, Professional & DIY Advice Relocated Toilet Drain Directly Above 2x10 Floor Joist Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Bubbling Toilet and Slow Tub Drain Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Toilet drain to merge in offset part of main stack? Aug 10, 2016
Plumbing Forum, Professional & DIY Advice Flushing Toilet, Coming Through Shower Drain... Only When A Lot Of Water Is Used Apr 25, 2016
Plumbing Forum, Professional & DIY Advice Connecting Shower drain to the toilet drain Mar 6, 2016
