toilet drain and vent layout
Discussion in 'Toilet Forum discussions' started by jimmie, Mar 15, 2005.
  1. jimmie
    jimmie New Member
    Mar 15, 2005
    ok...here's the situation...in laying out my new toilet on the second floor i was pressed for space in the ceiling joist area so instead of using a sanitary tee to dump the horizontal 3" from the toilet to the stack, i used a wye with a 45. Then on top ofthe wye i used a street 90 to continue on to the vent. My question is, is this ok. Will it fly (no pun intended) Here's a pic also of what i did..(note all the required distances are proper, i just cant draw on these computer things, so they look farther apart) Any help is appreciated[​IMG]
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    I'm not a pro plumber, but as long as the maximum distance between the toilet (built-in trap) and the stack/vent is not exceeded for 3", it should work fine, assuming that all is sloped 1/4" per linear foot.
    Call your Building Inspection Department for local code on the max distance between a toilet and the stack/vent for 3".
    Good luck!
    Mike
  4. jimmie
    jimmie New Member
    Mar 15, 2005
    well i know the distances are fine...i guess my actual question is about the drain/vent issue. Is this considered being vented before the discharge, and is the vent considered to be taking off below the drain? Im just getting opinions before I call for my rough in. Thanks
  5. hj
    vent
    The problem you might have, depending on the inspector, is that the vent from the street ell is "horizontal" and a strict interpretation of the code will not allow it to be horizontal until it is 6" above the overflow line of the fixture, or more likely 42" above the floor, since that is the usual stated minimum distance before it can go horizontal.
Similar Threads: toilet drain
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Feb 25, 2017
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions 180 degree turn on 3" toilet drain Sep 12, 2016
Toilet Forum discussions Is it the toilet or the drain/vent causing the constant clogging? Sep 11, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
