Toilet connection
Discussion in 'Toilet Forum discussions' started by BrianL, Jun 10, 2007.
  1. BrianL
    BrianL New Member
    Mar 11, 2005
    Raleigh, NC
    Hello All,
    Getting ready to re-tile my bathroom. Need to add some plywood, and will have cement board and tile on top. Is there an extension I can add to this, or do I need to cut out, extend the pipe, and add a new connector (sorry, I cant think of the name of this thing)? I am assuming this is a solvent-welded piece, so do I cut from the inside of the pipe? I have not screwed down the new plywood yet, in case I need to do anything different.
  2. jadnashua
    Wish you had come here first...yes, you can add extensions to the flange. The better way to do this would have been to cut it out, raise it up, then run the ply, cbu, and tile under where the rim of the flange would be, then install the flange. Ideally, the flange is installed on top of the finished floor.
Similar Threads: Toilet connection
Toilet Forum discussions Toto Aquia Dual Toilet with leak at connection of supply line and fill valve Mar 13, 2014
Toilet Forum discussions How to tell what kind of back to back toilet drain connection I have? Mar 6, 2014
Toilet Forum discussions Toilet, vent, and lav connections. Mar 31, 2010
Toilet Forum discussions Drake toilet water plumbing connection Oct 22, 2009
Toilet Forum discussions Pex connection to toilet Aug 21, 2008
