Toilet connection with flood protector ok?
Discussion in 'Toilet Forum discussions' started by Joerg, Feb 11, 2008.
  1. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Hello Folks,
    None of the local stores has 16" connector hoses anymore, only 12" and 20". Sometimes they do have 16" but those are versions with a built-in shut-off that somehow detects a catastrophic line break and shuts off the water so your house won't become a swimming pool.
    Can those "flood protector" hoses be used on pressure assist toilets or would they cause lots of nuisance shut-downs? How do these protectors work? Some kind of mechanical timer or do they detect pressure drops that are too sudden (and which a pressure-assist tank could cause)?
    Regards, Joerg.
  2. Terry
    Aug 17, 2004
    The Watts FloodSafe water supplies don't work with either Toto or Korky Quietfill valves.
    I haven't tried them with pressure assist toilets.
    [​IMG]
    [​IMG]
  4. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Thanks, Terry, then I might as well forget them for the pressure-assist. Interesting that they also don't work with more "normal" valves while being marketed for toilet connections. I wonder how many of these are being returned every day as "not working right".
    Doing another toilet right now. The tile guys managed to cause a substantial rigde smack along the middle. Guess I have to precision-cut some oak pieces to lift it a hair over that so that the toilet won't crack if big ol' Leroy plop himself down on it. It'll be more than 1/4" in some areas. Arrgh! :(
    Regards, Joerg.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The "Floodsafe" connectors are junk! They are prone to nussance trips and are a PITA to reset. When you think about it thet are actually quite unneeded, this safety valve is protecting a braided stainless steel no-burst hose. LOL
    In fact I recently had a customer that had his house flooded because one of these "Floodsafe" connectors broke. Interestingly the connector broke between the 3/8" compression connection that screws on the angle stop valve and the "Floodsafe" Valve. Breaking at this point the valve offered no protection and the "Floodsafe" connector flooded the home.
    The connector broke at the arrow
    [​IMG]
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    The fact that they're junk aside, I'll bet they would work fine on a PA toilet. There was no sudden monstrous inflow with the PA I had (Sloan Flushmate) -- just a normal fill rate as for any other toilet. The outflow, of course, was another story :eek:.
  7. jluksic
    jluksic New Member
    Jul 29, 2005
    Colorado
    Watts Floodsafe false tripped ~ 1 out of 10 flushes on our AS Cadet 3.
    [​IMG]
Similar Threads: Toilet connection
Toilet Forum discussions Toto Aquia Dual Toilet with leak at connection of supply line and fill valve Mar 13, 2014
Toilet Forum discussions How to tell what kind of back to back toilet drain connection I have? Mar 6, 2014
Toilet Forum discussions Toilet, vent, and lav connections. Mar 31, 2010
Toilet Forum discussions Drake toilet water plumbing connection Oct 22, 2009
Toilet Forum discussions Pex connection to toilet Aug 21, 2008
