Toilet clogs - sewege ejector pump water level above the toilet drain
Discussion in 'Toilet Forum discussions' started by rgamett, Jul 31, 2011.
  1. rgamett
    rgamett New Member
    Jul 31, 2011
    Las Vegas
    One of our toilet clogs, unless the sewege ejector pump is running. The water level in the pump drum is above the toilet drain. We tried to set it lower, but the flapper in the drump got stuck repeatedly. The toilet is right by the sewege ejector pump. Would it help to install toilet with more powerful flush. Right now the toilet has one of those water saving tanks...does not flush a lot of water.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    The problem is with the sewerage pump. The pump must come on before the water level is above the inlet to the tank. The float switch must be adjusted accordingly.
    John
  4. rgamett
    rgamett New Member
    Jul 31, 2011
    Las Vegas
    We got the water level adjusted lower, but the flabber was getting stuck with the toiletpaper,waste, ect, because of (then) the low water level in the sewege tank. The inlet to tank is pretty low. Is there anyway around this - would one of those toilets with more powerful flush help?
  5. jadnashua
    I don't think any toilet will work properly until you resolve the sewage ejector tank problems. If the slope of the pipe to the tank is not correct, or if the tank is so full it cannot take the entire contents of the flush before it is, it will likely continue to have the same problems.
  6. hj
    What "flapper" in the tank is getting stuck? There should not be any flapper in the tank. NO TOILET will flush if the pipe under it is full of water.
  7. jadnashua
    The ejector pump system will likely have a check valve in it, but that is to prevent much of what you pump out from rushing back into the pit when the pump turns off. There normally isn't any obstruction on the way into the pit from the drainage sources. And, if that path is full, no toilet will work properly. The inlet to the pit should be near the top to allow it to fall into the pit and not interfere with the float and have a chance of the pit having enough room to accept the waste.
Similar Threads: Toilet clogs
Toilet Forum discussions Kohler Canister toilet clogs Jul 7, 2016
Toilet Forum discussions Large hard stools (spinal cord injury) (parkinson's) current toilet clogs. Nov 23, 2007
Toilet Forum discussions toilet is backed-up, but slowly unclogs May 14, 2007
Toilet Forum discussions Kohler Rialto toilet causes drain clogs?? Jun 22, 2006
Toilet Forum discussions Toilet always clogs, no matter what Jun 5, 2005
