Dan Maranto
So this morning I got up, went to the bathroom and flushed, well the bowl just filled up with water so I shut it off. I go down to find water dripping slowly from around the toilet drain pipe in my master bathroom.
So I pulled the toilet off the flange, and it looked like the ring was not seated correctly. Maybe related to the slight leak, but I wouldn't think that would cause no flush.
Got it all put back together, turned the water on, flushed it twice, everything was good. Put all the tools away, came back up and flushed once more and the bowl just filled to the rim.
I tried plunging before and after I changed the ring. Both times, nothing. I emptied out the bowl this time with a solo cup, and noticed there were a few small air bubbles come out.
Is there a air vent per Toilet? Or just on the main septic drain line? We got a lot of snow over the weekend, thinking maybe the vent is blocked? Or do I just have a clog?
The other toilet in the house works fine. I'm just confused as to why I got 2 good flushes but then right back to nothing/just filling the bowl?
Any help would be great, thanks!
