Toilet cleanout location
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mlawrence, Dec 13, 2007.
  1. mlawrence
    mlawrence New Member
    Oct 4, 2007
    I've got a long run of 4" pipe that ends at a toilet. My plan was to put a combo wye with a cleanout at the bottom of the stack but I don't have enough room since the foundation wall is only about 15" away. Because of the long run the sweep 90 needs to be real tight to the bottom of the joists. I could put a cleanout after the sweep 90 (see attached dwg.)but that would mean the cleanout points up into a joist bay with joists 16" on center. This is my own home and that placement seems fine to me but is that a code violation of any sort or do any of you plumbing guru's have an alternative??
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Use a test TEE or clean out TEE.That way you have more clearance.
  4. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I would do that or if you are installing this you could go with 3" and get a bit more room.
Similar Threads: Toilet cleanout
Plumbing Forum, Professional & DIY Advice Toilets, horizontal wet vents, and end of line cleanouts Jan 2, 2015
Plumbing Forum, Professional & DIY Advice Toilets won't flush unless cleanout plug off Sep 1, 2014
Plumbing Forum, Professional & DIY Advice Convert Toilet to Cleanout? Dec 2, 2012
Plumbing Forum, Professional & DIY Advice Toilet Cleanout setup. Nov 8, 2011
Plumbing Forum, Professional & DIY Advice Can the toilet be used as a cleanout for waste line in concrete? Jun 30, 2009
