Toilet bowl water level
Discussion in 'Toilet Forum discussions' started by inovermyhead, Sep 29, 2005.
  1. inovermyhead
    inovermyhead New Member
    Sep 29, 2005
    How can I adjust the water in the bowl. I have "dry bowl" and smells..
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    dry
    [​IMG]
    There is a small refill tube that comes off from rhe ballcock or fill valve inside the toilet tank. There has to be a stream of water that comes out of that tube. And that stream of water has to be directed to the tank overflow. The overflow may be a tube standing near the flapper or it may be a part of the tank casting.
    Look and see.......
  4. Terry
    Aug 17, 2004
    [​IMG]
    If the fill tube is in place, then the other determining factor is the height of the bend of the trapway.
    The top of the bend, is like a "dam" holding water in the bowl.
    The water will not go higher than the dam.
  5. jimbo
    jimbo Plumber
    The water level in the BOWL is not adjustable. Possibly you are getting no refill from the tank; also possible is a bad vent causing siphomn action, or a crack in the throat of the toilet/
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    water spots
    booster....what is a water spot?
  7. hj
    spot
    The surface area, and Terry whose toilet is that a cutaway of? It comes awfully close to being double trapped.
  8. Terry
    Aug 17, 2004
    That's a Briggs Vacuity.
    Though it's becoming a trend for leaving some water in the lower trapway to create more siphon.
Similar Threads: Toilet bowl
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Tuesday at 3:32 PM
Toilet Forum discussions Toilet bowl slowly leaks water Dec 15, 2016
Toilet Forum discussions Toilet bowl is tilting over half an inch due to small wood pieces placed under Oct 26, 2016
Toilet Forum discussions Toilets for Large Waste PLUS Good Bowl Wash Aug 21, 2016
Toilet Forum discussions Using muriatic acid to clean mineral buildup off of toilet bowl Aug 2, 2016
