Toilet Bowl Water Level Alternates Level and Flush
Discussion in 'Toilet Forum discussions' started by leichte, Sep 5, 2010.
  1. leichte
    leichte New Member
    Sep 5, 2010
    NC
    My toilet bowl is starting to alternate water levels of about an inch below and an inch over normal bowl levels. When the level is low the toilet doesn't flush all the way. When it's high is does. I've adjusted flapper chain but still not working. This has been driving me crazy. Should I just replace all the guts in my tank?
    Any thoughts?
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    It could be the tube that goes from the fill valve to the overflow tube, this fills the bowl as it fills your tank.
  4. jadnashua
    A bowl only has one 'right' level. If the drain pipe is not clogged, it can never go higher than the 'right' level (which is determined by the weir in the construction). If the fill valve is not working properly, or was replaced with a generic version, the refill after a flush may not be filling the bowl properly. A generic version fill valve MIGHT not have the balance between water to the bowl and water to the tank correct, and the tank refills before the bowl is full. Often, it's the other way around, but then that wastes water - it just goes over the weir and down the drain.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Did you recently change the flapper just before this started happening?
    Installing a 1.6 GPF flapper on a 3.5 GPF toilet will cause the water level to alternate....
    Usually with a good flush every other flush as well.
Similar Threads: Toilet Bowl
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Toilet bowl slowly leaks water Dec 15, 2016
Toilet Forum discussions Toilet bowl is tilting over half an inch due to small wood pieces placed under Oct 26, 2016
Toilet Forum discussions Toilets for Large Waste PLUS Good Bowl Wash Aug 21, 2016
Toilet Forum discussions Using muriatic acid to clean mineral buildup off of toilet bowl Aug 2, 2016
