Toilet Bowl Seal
Discussion in 'Toilet Forum discussions' started by schipperke, Mar 24, 2011.
  1. schipperke
    schipperke New Member
    Dec 10, 2010
    Maryland
    I have seen some photos of toilet installs where the white silicone <?> sealer around the bowl at the floor does not extend to the rear of the base. Is there a reason for this? I can't recall seeing a toilet done that way here, the sealer goes all around.:confused:
    (I did try searching first)
  2. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    The silicone around the base of the toilet is to keep water splashed on the floor from seeping under the toilet and damaging the for or the ceilings below.
    I like to leave the back open so that if there is any leakage at the toilet flange there may be an indication before the floor rots out.
    Michael
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Most plumbers would use a latex caulk rather than silicone because silicone is difficult to remove if/when the toilet needs to be pulled.
  5. Terry
    Aug 17, 2004
    Silicone pretty much ruins a floor. You can't ever get it off, so if you ever decide to go with a different bowl, you're best to just replace the floor at the same time.
    Plumbers use water based caulk.
    In Arizona, they caulk 360
    In Washington, they don't caulk the back, that way you notice a leaking seal in time to prevent the toilet from dropping right through the floor.
    Arizona doesn't have wood floors.
  6. schipperke
    Dec 10, 2010
    Maryland
    Thanks much guys !
  7. hj
    Arizona has few wood floors in our bathrooms, but we DO have inspectors who check the rear of the bowl to be sure the caulking was put there.
    [​IMG]
Similar Threads: Toilet Bowl
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Toilet bowl slowly leaks water Dec 15, 2016
Toilet Forum discussions Toilet bowl is tilting over half an inch due to small wood pieces placed under Oct 26, 2016
Toilet Forum discussions Toilets for Large Waste PLUS Good Bowl Wash Aug 21, 2016
Toilet Forum discussions Using muriatic acid to clean mineral buildup off of toilet bowl Aug 2, 2016
