ToeKick Hydronic heater installed wrong... what to do??
Discussion in 'Water Heater Forum, Tanks' started by pdx.drippy, Dec 3, 2010.
  1. pdx.drippy
    pdx.drippy New Member
    Dec 3, 2010
    oregon
    A friend of mine had a plumber install a small toekick hydronic heater a few years ago & it never ever worked properly. There is a regular old 50gal electric H2O heater next to the bathroom. The "plumber" put in 3/4, 3/4, 1/2 T in the top of the water heater. 3/4" cold enters from the top & 3/4" hot exits vertically. 1/2" parts exits (all in PEX) to a recirculator pump & then to the heater & returns on the 1/2" part of the cold Tee. There are shut valves on both the 1/2" hot & cold at the water heater.
    anyway, there is some mixing of hot & cold now, do I need to put in some kind of check valve somehwere? mixing valve? she'd like to use the thing. this is in portland, oregon....
    thanks in advance for any advice
  2. hj
    Of course there has to be a check valve in the system somewhere, otherwise, depending on pressure differentials, the cold water could flow through the radiator and enter the hot water piping.
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Well if it never worked then why wouldn't that friend have called the plumber back to fix it? It could be a few problems, the dip tube in the HWH could be cracked causing a mixture of cold and hot. It could be a failed check valve or an element/thermostat on the HWH not working.
    Also what temp is the heater set at? Hyronic heat is usually higher than a regular HWH.
  5. pdx.drippy
    Dec 3, 2010
    oregon
    I put in a spring loaded check valve in the return, just b4 the cold water T.
    THx 4 the advice on raising the temp, its not working that great right now.
    will get a mixing valve to tone donw the temp of the hot water 4 the taps.
    the other "plumber" was clueless i guess... oh well, thx again 4 the replies
  6. hj
    quote; the other "plumber" was clueless i guess
    Being a "plumber" does NOT make you a heating expert, or even a "heating man". The two trades have different requirements, even though both work with pipes. You would NEVER ask a heating man to fix your faucet, would you, (or does it depend on how much he would charge you)?
Similar Threads: ToeKick Hydronic
Water Heater Forum, Tanks Help w/ piping to hyrdoheat hydronic aquatherm First Co combo heater Nov 30, 2011
Water Heater Forum, Tanks Underfloor hydronic in the Northeast? Oct 28, 2009
