Todays plumbing fun....
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rich B, Apr 13, 2009.
  1. Rich B
    Rich B DIY Senior Member
    Sep 13, 2008
    New Jersey
    OK tonight when I got home from work I decided to start working on removing my 50+ year old Kohler cast iron tub........Tried a sawzall with one of those special blades for cast iron.......would have taken forever.....and was clearly a waste of time.......had a 2 lb hammer......gave it a few whacks.....another waste of time...time for the heavy artillery.....big sledge hammer and covered it with a moving blacket.......Success...busted it up...got it out without and damage to the rest of the plumbing and that was very important as this is a 2 family home with bathrooms back to back and I need to keep my side operational.........So now I have much better access to the rest of what I need to do......replace a horizontal 4" C.I. waste branch that serves both sides......Pitch is UP to the vertical stack, not down and cast iron and lead bends will be gone soon....
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Man been there done that to many times,sucks that you had to do it after
    working all day.
  4. hj
    tub
    The next cast iron tub I remove by busting it up will by my first one. I ALWAYS remove them in one piece, (doing it correctly makes it a one man job), so no shrapnel, no cleaning up busted pieces, and no destroyed moving blanket.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    I don't know why not busting it up would be the correct way and busting it up is the wrong way, but I do know that busting it up with a hammer makes it much lighter to carry out and much easier to navagate through the house...my back thanks me all the time and the homeowners like the fact that their house had 1 less thing to possibly cause damage.
    hj...do you cary them out or use a dolly or how do you do it when it is in very tight areas...by your self...
  6. Rich B
    Sep 13, 2008
    New Jersey
    Good luck with that HJ! I have another one in the other bathroom.....anytime you want to show me how it's done I'll be here waiting for you......It's a 5 x 8 bathroom.....tub is a Kohler cast iron made in the '50s and it's on the second floor.......Seems like everyone of your posts is the same....someone is not doing things up to your standards or is beaking a code......You must be the Picasso of plumbers and mighty strong to be able to remove a cast iron tub by yourself and in one piece........I would guess that tub weighed a couple hundred pounds +.....Oh and the moving blanket survived and so did I.....All you need is an 18lb sledge....a broom and a dustpan and a garbage can and good legs to go up and down a flight of stairs carrying two pieces at a time. And a metal dumpster and I have that as well.....I'm 61 and it was good excercise.......If you get one you need busted up, call me...I'll do it just to relieve tension...LOL
  7. hj
    tub
    A second floor tub would need a second person to get it down the stairs, unless it was like one my dad did years ago. Him and the helper left the tub on the porch while they went inside to check something and when they came out the porch, stairs, AND tub were on the ground below. I did not say it was wrong, I just said I would never do it that way. If done correctly the tub comes out very easily, and if you are going to install a new tub, once you get it out you know how to insert the new one. OF COURSE I use a dolly to move it. The tub weighs quite a bit more than I do. Breaking it up just creates a lot of unnecessary mess and noise.
  8. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    HJ...The Picasso of Plumbers...
    Does have a certain ring to it. Like cast iron when it's being busted up... :)
  9. hj
    Tub
    If you are going to bust the tub up, why not make it interesting by leaving the blanket off. It would be like the high school restroom years ago when kids put an M-60 firecracker between two urinals.
Similar Threads: Todays plumbing
Plumbing Forum, Professional & DIY Advice Todays worst plumbing repair with a shampoo bottle... Dec 9, 2016
Plumbing Forum, Professional & DIY Advice todays trivia question- Feb 18, 2014
Plumbing Forum, Professional & DIY Advice Plumbing sink with no overflow. Please help Thursday at 9:02 AM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Plumbing with PEX, which option to choose Feb 20, 2017
