Stephen B
I have just finished chasing and fixing multiple leaks on my upstairs bathtub drain system. Re-did the S trap and drain shoe piping. Replaced the overflow fitting / plate and gasket. Everything now works fine - no leaks.
The old overflow PVC fitting on the outside of the tub had a 3/4" threaded fitting at a 45 degree angle that the attic vent line connected to. The new PVC fitting I installed does not have this provision.
Questions:
1. Do I need to worry about this? The tub drains fine - no gurgling or slow drain.
2. If not, do I cap off the 3/4" line running up to the attic? - or will this be a problem with rain water...?
Thanks for any input
Questions:
