To plug or not to plug into a GFCI outlet
Discussion in 'Electrical Forum discussion & Blog' started by DIY, Apr 6, 2009.
  1. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Happier, yes. . .
  2. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    You are not taking harmonic noise into account. The power line voltage waveform is not a sine wave and the extra frequency's add to the current.
    And then there is the long range power utility communication systems. These can add quite a bit of noise spikes. The worst is the DCSI TWACS system (90 amp pulses at the house), then there is the cannon EMETCON(9Khz to 12Khs) and the L&G TS2 system(560Hz).
    All these can add quite a bit of current and that is why the Capacitor & diode power supplys have a series resistor to limit the current from higher frequencys.
  3. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Boy we sure made a big jump here from a MOV to the power company’s grid and the harmonics found on that grid.
    The important part of this is the fact that we are not affected by the primary harmonic currents of the power grid. The transformer at our house only steps down voltage and not current. The amount of current draw at our homes is solely based on the loads we have not how much current the primary lines are carrying.
    Once again not on the circuits in our homes. The TWACS system is a software system that was designed by Distribution Control Systems, Inc. (DCSI), a subsidiary of ESCO Technologies Inc. and is mostly used as a load control program to ensure the end customer always has power.
    The newer version NG 3.0 can often times detect a grid outage and reset the breaker before the homeowner knows the power was out. It can detect this so fast that a lot of electronic clocks never stop working such as the clock on microwaves.
    Again Brother Bill the amount of current on the primary lines of the utility company in no way affects the current on a 120 volt branch circuit that is protected by a GFCI device in our homes. The harmonics on the utility primary power lines does not enter our homes either. These harmonics are lost at the step down transformer that supplies our homes.
  4. Ian Gills
    Jul 24, 2007
    USA
    I have a GFCI on my sump pump and it has never tripped by accident.
    Similarly I have a GFCI on my condensate pump.
    Each life can be valued at about US$2 million. To protect me and those around me, these are a pretty good investment.
    All within 6 feet of water source.
  5. Bill Arden
    Sep 30, 2006
    computer programmer
    MN, USA
    1. When you draw currents from a outlet that WILL affect the voltage since the transformer has both resistance and inductance. The higher the frequency the less current you need to change the voltage. At 10Khz it does not take much current to change the voltage.
    2. the DCSI TWACS system includes a AMR(Automatic meter reader) component and that meas that it includes a module that mounts inside the house electric meter. That unit uses a Triac to pull 90 amps just before the zero crossing. These pulses of current can cause problems and is part of the reason the AMR part of the system has been banned from some states.
    3. There is a "voltage noise test" that units have to pass and that is probably why the 0.09 uF value was stated. It's not that 0.09 uF will trip a GFCI, but that it MIGHT trip a GFCI.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    .09 uF @ 60 Hz is 30kΩ, 120v/30kΩ = 4 mA, which is just about the trip threshold for a GFCI.
    ROMEX® has about 100 pF/ft, so 900' of ROMEX® should trip a GFCI.
  7. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Bill I know that you are trying hard but the simple answer is none of this will affect a GFCI.
    If other than the 60 Hz sine wave would affect a GFCI then there would never be a listing on items such as the X10 control systems sold to control lights throughout a home. These devices send signals across the electrical wires that are different than the 60 Hz sine of the voltage being controlled.
    The automated meter readers you have referred to in your post is connected in parallel with the home so any currents or harmonics introduced by this item would end at the point of use and not be transmitted into the home.
Similar Threads: plug plug
Electrical Forum discussion & Blog Can I plugin a 240V into a 250V receptable? Apr 19, 2016
Electrical Forum discussion & Blog How to connect L14-20 plug to normal plug ? Apr 19, 2016
Electrical Forum discussion & Blog What to do with wires when installing light switches/plugs Sep 9, 2013
Electrical Forum discussion & Blog Plug on Lamp Fixture in Cabinet only came with One Prong Jun 28, 2011
Electrical Forum discussion & Blog Industrial wall fan misting on covered porch - not UL507 rated plugged into GFI Jun 10, 2011
