To pigtail or not to pigtail?
Discussion in 'Electrical Forum discussion & Blog' started by Verdeboy, Sep 22, 2007.
  1. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I had to replace a receptacle today that had 3 hot wires and 3 neutrals connected to it. Two hots and two neutrals were "stabbed" and one of each was screwed. The receptacle I bought was labeled "heavy duty" and had no holes for stabbing.
    I ended up using one screw for two #12 wires on both the hot and neutral side. Is that kosher, or should I have pigtailed the wires together instead, so only one wire per screw?
  2. jimbo
    jimbo Plumber
    Two wires on one screw is not acceptable. The type of receptacle I prefer is what they call "back-wired". This is NOT the same as "quickwire" or " backstabbed". The "backwire" has opening holes on the back side. You insert the wire and when you tighten the screw, it clamps the wire. Very secure. It accepts 4 wires on each side ( 4 black, 4 white.)
  4. jadnashua
    One wire per screw. You've got a loose connection waiting to happen.
  5. Verdeboy
    Jun 12, 2006
    Okay, I'll have to re-do it using the back-wire receptacle.
    But I really did tighten the heck out of those screws and clamped the wires down extremely tight. Much better than the previous stab connections that were pretty easy to pull out.
  6. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Is there no room to use wire nuts to join the three sets of hot and neutral, along with more wires going to the spec-grade receptacle?
  7. Verdeboy
    Jun 12, 2006
    There actually is very little room in that box for any additional wires and wirenuts. But, that's why I asked the question. I thought my only two options were pigtailing all the wires together and running a wire to the outlet or doubling up on the screws. But, Jimbo's back-wiring suggestion makes the most sense.
  8. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Very little room might be enough, if you really wanted to use spec-grade receptacles. Was there a reason for selecting spec-grade in the first place?
  9. Verdeboy
    Jun 12, 2006
    I actually just bought the cheapest receptacles ACE had. Apparently they don't carry the standard ones. I'll just get my receptacles from the elect. supply shop from now on.
    Is it actually a code violation to double-up or is it just a lame-brain thing to do?
  10. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    What the he**. A broken resolution's not worth keeping anyways, right?
    Both. :)
    It's got something to do with when one wire's under load, and the other isn't, they expand & contract at different rates, or something like that... Mike will be able to explain better; but the point is just that it can work itself loose, even if it seems solid right now.
  11. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Maybe those were old inventory. Usually, a spec-grade item costs more. Pay more, and no back-wiring - great deal, what?
  12. hj
    wire
    Our inspectors enforce the "one screw/one wire" rule, even on circuit breakers where you could conceivably put one wire in each groove on either side of the wire clamp.
  13. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Get in touch with Square "D" conpany and let them know about this enforcement and it will go away.
Similar Threads: pigtail pigtail
Electrical Forum discussion & Blog pigtail or screws in receptacles Jan 27, 2009
Electrical Forum discussion & Blog No Pigtail, Interesting Wiring, Dec 31, 2008
Electrical Forum discussion & Blog Pigtail, forced air heater Dec 16, 2007
Electrical Forum discussion & Blog Aluminum pigtails from certain fixtures Oct 25, 2007
