tk Jr. runs only with cover off
Discussion in 'Tankless Water Heater Forum' started by howgag, Feb 10, 2012.
  1. howgag
    howgag New Member
    Feb 10, 2012
    Ontario
    My takagi Tk jr. will only run with the cover loose or off. IT's 6 years old & worked fine until I removed the cover to change an "O" ring in the water control valve. If I try to run it with the cover on it trips out. Any ideas or solutions appreciated. thnx. runs fine with cover off.
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Do you have a remote, so you can read the error code? "Trips out" as a symptom description doesn't say much, but the self-diagnostic error codes can sometimes zoom right in.
    Takagi's telephone tech-help would be the next step, but have the manual in front of you when you call.
  4. howgag
    howgag New Member
    Feb 10, 2012
    Ontario
    Unit works fine with the cover off or bottom screws left off so the bottom hangs out letting it get more air. Tighten the screws, & it will trip the internal breaker & cover has to be removed to reset it, Don't get any codes. always worked fine till I had the cover off to replace the water control valve. any help greatly appreciated.
  5. howgag
    howgag New Member
    Feb 10, 2012
    Ontario
    THE unit seems to have cleared itself up, Works fine now with the cover secured.
Similar Threads: runs cover
Tankless Water Heater Forum Hot Water Helper for long runs. Apr 17, 2011
Tankless Water Heater Forum Rheem ECO-180DVP only runs with low water flow Jan 1, 2011
Tankless Water Heater Forum Takagi's new T-H2 - PVC Venting and Heat Recovery Oct 15, 2009
