Tired of Mixet shower handles
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sdcabob, Apr 21, 2006.
  1. sdcabob
    sdcabob New Member
    Apr 21, 2006
    I'd like to replace 2 showers with Mixet with a different brand. I'm told that these pieces must be replaced with same brand due to match with valve.
    True? Or are there other brands to choose from that can fit on these valves too?
    Am trying to avoid going through tile and dry wall for repair if possible. Thanks!
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    they are junk
    no, you are screwed....they are a pain
    you will have to cut them out from behind
    and preferrably install DELTA 1700
    pressure balanced faucets....
  4. hj
    valves
    Once you access the brass part in the wall, you can install any valve you want to. But I also prefer the Delta 1700 series.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    You cannot REPAIR your shower with anything but Mixet parts. Faucet parts are not generic at all......must match brand and model. The best you could to is possibly find a brushed nickel escutcheon. Mixet parts are getting scarce.
    If you can get access inside the wall, from the front OR from the backside, then you can install any new shower valve you wish.
    [​IMG]
    Mixet
  6. hj
    mixet
    Jimbo. One company makes a Moen style cartridge for the Mixet which eliminates the crossover problem common with Mixets.
  7. jimbo
    jimbo Plumber
    San Diego, CA
    Thanks hj. I jave heard of that anit-crossover cartridge, but have not used it. My point was also that choices of upgrading the "look" are limited to the brand. Does that aftermarket cartridge require still the Mixet handles, or doe it use Moen handles and trim. If the latter is the case, that would open up a few more opportunities as far as handle and trim styles and colors.
  8. hj
    mixet
    I haven't used any either, but I had many apartment complexes in the early 70's that had serious crossover problems to the point where the apartments at the end of the runs could not get any hot water at all. These would have fixed them. They use the Mixet body, so you have to use Mixet trim.
  9. schneider120@hotmail.com
    schneider120@hotmail.com New Member
    Jul 25, 2009
    DID YOU EVER FIND OUT OF YOU CAN USE OTHER NON MIXET TRIM AFTERWARD?
  10. hj
  11. jimbo
    jimbo Plumber
    San Diego, CA
    Notice the price on the NOMIX. You have to be dedicated to stay with Mixet/
Similar Threads: Tired Mixet
Plumbing Forum, Professional & DIY Advice Mixet Shower, DIY professional plumbing repairs Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Mixet valve replacement gone bad after a week Jul 6, 2015
Plumbing Forum, Professional & DIY Advice questions on replacing Mixet cartridge. Jul 3, 2015
Plumbing Forum, Professional & DIY Advice Mixet balance spool probably clogged Jul 19, 2014
Plumbing Forum, Professional & DIY Advice Possible reasons a mixet valve would shoot out of the socket? Jul 9, 2013
