Timer Placement
Discussion in 'Irrigation / Sprinkler Forum' started by RTP, Aug 7, 2009.
  1. RTP
    RTP New Member
    Jul 10, 2008
    I want to install my timer in my garage. It is not heated and will freeze in the winter. Should I install an outdoor timer or will an indoor also work.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The timer is an electronic device and is not subject to freezing problems. I'm not sure, but it could be affected by moisture. I would locate it as close to the manifold where the valves are as is possible/practical. Cut down on the wire runs as much as possible, and keep it as simple as possible. This might not work for you, but mine is on my basement wall and the manifold is on the outside of the same wall directly opposite. The wire lengths are less than 4' each and nothing is buried. I must be OK, it's been working fine for 25 years.
  4. onedrop
    onedrop New Member
    Aug 7, 2009
    Indoor Timer vs. Outdoor Timer
    In all the timers we sell http://www.sprinkler.com/buy/controllers
    Outdoor: Transformer is built into the timer and needs to be wired with a pigtail.
    A door is provided to protect against the elements
    Indoor: Transformer is on the outside and plugs directly into an outlet.
    Usually does not have a door.
  5. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I'm still suprised when I see new installs with the valve manifold buried (down here at least), even my neighbor buried his after I suggested he match what I have. He had to mess with a couple of his solenoid valves and finally understood why I suggested what I did.
Similar Threads: Timer Placement
Irrigation / Sprinkler Forum Is it against code to connect a timer to a hose bib? Yesterday at 8:49 AM
Irrigation / Sprinkler Forum Timer for irrigation pump? May 13, 2016
Irrigation / Sprinkler Forum progams A and B rainbird ESP-Me Controller Timer Jun 11, 2015
Irrigation / Sprinkler Forum Intermatic FM/1 timer losing time Jan 23, 2015
Irrigation / Sprinkler Forum Possible to run off a pressure tank and a timer for two seperate functions? Apr 12, 2014
