Manicmechanic
We recently purchased a home that was constructed in 1992, it's a 2 story home that has one water heater (50 gal.) located in the garage at the south end of the home. The master bath is on the north end of the home and requires the shower to run for about 1-3 min. before water is warm enough to enter and close to 4 before the temp is at its peak level. This varies due to outside temps and since we haven't been in the home during the winter season I'm afraid it will be worse. The showers water pipes are on an inside wall coming up from the slab, the tank shows to be about 7 years old as it is an Envirotemp running on NG. Does this sound like a failing WH or just too long a run from the heater to the Shower to expect hot water any sooner. Is there any way to boost the temp of the water to the shower until the water heater catches up? We seem to be using a lot of water to get it to a comfortable temp to allows one to enter and shower. I estimate the distance of the shower from the heater @ about 100' or more, since I don't know how the pipes are run in the slab.
Thanks
Thanks
