Tiling over Tile
Discussion in 'Remodel Forum & Blog' started by jkkh1106, Apr 4, 2008.
  1. jkkh1106
    jkkh1106 New Member
    Apr 2, 2008
    I have a shower that I recently re-tiled. However when I laid the shower floor I did a poor job around the drain and now I am left with a few low spots around the drain, now I am getting standing water in my shower. I am wondering about tiling over what is there now to make the correction instead of ripping the entire floor. Any thoughts?
  2. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    That would be a really terrible idea. If done properly you would have to rip out the first row of wall tile, tear out the floor, use a cement bonder and re-slope. Then re-lay the tile.
    You may want to check out www.johnbridge.com. They'll set you straight.
    Tom
  4. jadnashua
    It sort of depends on whether you have birdbaths in your sloped floor, or the overall slope is not correct.
    Raising the drain to accommodate a second layer of tile may not be possible. I may be possble to remove the floor tile without compromising the liner...depends, it can be risky.
    Many people put the floor tile in first, then cover it with the wall tile. This is not a requirement, it's just easier since the edge cuts look crappy if you don't get them straight - the wall tile going over them helps hide things. It is eminently possible to leave the wall tile in place and tile up to them. Industry standards call for that gap to be caulked rather than grouted. You could risk it and grout it, but it might fail. Doing it either way can look good...good workmanship is critical, though if you want it to look good.
  5. jkkh1106
    jkkh1106 New Member
    Apr 2, 2008
    I do believe the slope is fine, and the drain is able to accommodate a higher floor. I just want to make sure if I do it, I do it right.
  6. gizza job
    gizza job Plumber
    Apr 4, 2008
    plumber
    Barrie, ontario
    existing tiles are one of the best surfaces to tile to so if you are confident of raising the drain and gettin the correct fall into it and keep it water tight i say go for it!
  7. hj
    drain
    You might have to raise the floor more than you think to get a good bond between the two tiles. Unless the tile was seriously out of kilter, the drain should not be high enough to accomodate a second layer of tile.
Similar Threads: Tiling Tile
Remodel Forum & Blog Subfloor question for tiling a bathroom floor with heat mat under the tiles Sep 2, 2011
Remodel Forum & Blog Tiling a laundry/furnace room Nov 3, 2011
Remodel Forum & Blog How to prep a laundry room floor with floor drain for tiling? Aug 28, 2010
Remodel Forum & Blog Bathroom Tiling Jul 5, 2010
Remodel Forum & Blog Basement Bathroom Tiling Installation Questions Mar 6, 2010
