Tile setting - use of premix grout to level surface?
Discussion in 'Remodel Forum & Blog' started by AcidWater, Mar 20, 2009.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    I have a really small tiling job.
    I have a concrete ledge sticking out from a brick wall. Its about 6' long, projects about 9 inches from the wall, and is about one brick high. It is the remains of a fireplace pit.
    From left to right it is not level; on the right it is higher by 3/8".
    It also slopes downwards a bit from the wall.
    I bought a small container of colored pre-mixed adhesive/grout made from limestone & polymer
    How thickly can I spread this stuff -- can I use it to level the surface as I set the tile, or do I really have to put on a skim coat of patching cement?
  2. jadnashua
    Most pros consider the pre-mixed stuff junk and expensive. It stays soft in the bucket because it needs to dry out to do anything, and can re-emulsify if it gets wet again. It will take a LONG time to set that thick, under a porcelain tile, months. You'd be much better off with some real thinset for this and to set the tile. Note, though, you should do this is a couple of layers since it really is meant to be THINset. An alternative would be to buy a bag of medium set (often called granite and marble) mortar...it has more sand in it and can be installed up to about 1/2" thick (thus, the medium set as opposed to thinset). That can also be used to set whatever tile you want.
  4. AcidWater
    AcidWater Member
    Oct 14, 2008
    The premix was cheaper than a bag & colored too. Guess I'll have to do it the other way.
Similar Threads: Tile setting
Remodel Forum & Blog Setting mosaic floor tile Apr 21, 2009
Remodel Forum & Blog Bathroom Reno - Adding new tile and heating Jun 19, 2016
Remodel Forum & Blog Can I install a tub now and put up a cheap surround then tile later? Feb 6, 2016
Remodel Forum & Blog Cantilevered bumpout Jan 5, 2016
Remodel Forum & Blog Tiled Doorway In Adjoining Areas Feb 24, 2015
