Tile has Gap around Toilet
Discussion in 'Toilet Forum discussions' started by ecu pirate, May 5, 2007.
  1. ecu pirate
    ecu pirate New Member
    May 5, 2007
    Hi,
    I am in the process of tiling all 3 of my bathrooms, as there was carpet before (weird!). I started with my downstairs 1/2 bath since it is smallest. I got all the tiling done, and have begun to replace the pedestal sink (done) and the toilet. Upon installing the new toilet with a much thicker wax seal, there is about a 1/2" gap around the toilet base. I just placed in the tiles square around the flange. Here is a pic
    [​IMG]
    What can I do short of putting in tiny pieces of tile around the flange?
    george
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    If you don't want to add any more tile, you can either grout or caulk around the base of the toilet.
  4. Terry
    Aug 17, 2004
    Looks like you should pull the bowl and finish tiling.
    A set of nippers or wet saw should help here.
  5. ecu pirate
    May 5, 2007
    i ended up putting down some more tile pieces and grouting, and it now looks good. however, the wax seal i bought didn't seem to provide a good seal the first time i tried to use it. i used a "fluidmaster" no-seep no. 3. what would be recommended to make up for the new slightly higher tile floor?
  6. Pewterpower
    Pewterpower New Member
    Jun 25, 2006
    sales
    Tampa
    A flange extender should suffice. It's like a giant washer that goes over the top of the flange to give it a little more height. If that still doesn't want to seat, try using two wax rings stacked together.
Similar Threads: Tile around
Toilet Forum discussions Tile not level around Toilet. Jul 26, 2009
Toilet Forum discussions Wet tile around the toilet Aug 23, 2007
Toilet Forum discussions new tile under flange or around it? Jul 22, 2006
Toilet Forum discussions Sani Seal with Offset Flange 1/4" Above Tile Floor Jan 5, 2017
Toilet Forum discussions Uneven tile so flange does not sit on top Dec 19, 2016
