Tightening tank to bowl: Advice please
Ron in SC
South Carolina
I brought a American Standard Cadet 3. Everything installed except tightening of tank to bowel. Directions say to tighten until tank just rests on bowl. I've tightened a fair amount and fasteners seem pretty tight. Do not want to overtighened and crack something. Gasket is installed between tank and bowl per directions, tried flipping the gasket the other way around and it would not work at all.
Photo shows the space between tank and bowl.
Jimbo
San Diego, CA
I don't use wrenches on the nuts. Lean down on the tank slightly to compress the gasket. Spin the nut up by hand some. Do this in gradual steps, alternating one side and the other, until you are where you need to be.
wrench
I cannot imagine tightening a tank properly without using a wrench. I use a 3/8" drive rachet but use minimal force when tightening the bolts. It is a judgement thing that you learn when it is enough.
Ron in SC
South Carolina
For whatever reason this tank could not be tightened as designed. I was able to tighten it so tight that the tank was on the bowl on only one side. I did tighten it incrementally but with no success. I must have tried tightening it a dozen times before I finally said ok that's enough. I returned it to Lowes.
I know the Cadet 3 are recommended by people on the board but I think that American Standard lacks a quality control department.
The other Cadet 3 that I returned to Lowes yesterday lacked glazing on part of the tank that was very visable with the tank cover in place. It also lacked a seat which was to be included. They did give me a seat but like I say I ended up returning it anyway because of the lack of glaze.
The same person handled my return yesterday handled the one today. I asked her if they get a lot of returns on American Standard and she said yes.
I don't recommend the Cadet 3, except in special circumstances.
They are a cheap, poorly made toilet with very little quality control.
Professional plumbers would do well to avoid them, if they intend to consistently operate with normal profit levels.
It's more for the homeowner looking to save a buck, that has time, time and time on their hands.
If you read the whole thing, people say that that toilet works, but the QC is lousy...if you get a good one, no problem. The pros typically can't afford to take the time to sort out a good one from the lousy ones, so they shy away from them. If you want to play QC inspector and take multiple runs back to the store to find a good one, you may get a bargain if you don't value your time.
Ron in SC
South Carolina
So would a Toto Drake be what I need to get. This bathroom is very tiny, only a toliet and a 32" x 32" shower and it's in my detached garage.
Redwood
No Kidding!
When I go and pick up a toilet and install it, I have to guarantee it.
If I have to do it twice or, return and do it again because the installed product is defective it's money out of my pocket!
When it happens too frequently with a given manufacturer they end up on my s**t list. Am. Std. has been on my s**t list a long time and has virtually no hope of getting off it! When a manufacturer is on my s**t list, I will not install their product if I provide it.
To get off my s**t list I'm going to have to install a lot of customer supplied Am. Std. fixtures with no defects and thats not happening as I see close to a 50% defective rate. I do not guarantee customer supplied fixtures so that is the only way I now install Am. Std. The only guarantee with customer supplied items is that I install them correctly. If they don't work I'll put in another at a price.
Did you know that I have never had a defective Toto Drake or, had a callback on one yet?
crmoores
tank to bowl, Cadet 3
I am also just installing the tank and have the same gap as pictured in Ron's question. I want to tighten further per the directions but fear the worst. So I will turn on the water and see what happens!:eek:
TheZster
Fort Collins, Colorado
I've installed 7 cadets in the past two years... they work - they're cheap - and no one has complained to date. Keep in mind - I'm in the fix n flip business - and put these in my lower priced homes.... though I also have to admit I put one in two of my last personal homes recently.... I'd love to be able to recommend a spendier toilet system... but - so far - I can't.
I've never been able to get the tank all the way down to the toilet either - but if it doesn't leak, doesn't fall off the tank.... then it's not a problem..
Many builders and flippers us less expensive products.
People know that, so what is there to complain about.
They know you didn't put in the best,
And that's why people complain about the builder, not the components.
I make a living out of replacing builder grade components.
We're just in a different part of the business.
I've built homes before, so I know where you are coming from.
A builder may be working on a 5% margin. There isn't much wiggle in that to make it better.
