Tightening loose handle on Moen 6610 bath faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Chad Schloss, Jun 7, 2012.
  1. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    I have the directions that came with the faucet. It says to remove the caps ontop of the handle.. problem is, these do not look like caps, and i have already tried prying at one and scratched it. I even went on moen's site and looked at the tech specs/pdf's, etc and they made two different ones it appears, one with caps, and the other just shows a pictoral of a handle kit you can order, with no mention of the caps or how to remove them.. any ideas, before i go scratching up these supposed caps again?
    http://www.moen.com/brantford/chrom...:6610;jsessionid=99155eceb61c1088a3da5572e4fa
      File size:
      29.8 KB
      3,434
  2. hj
    If the faucet was made AFTER September 2009, there is NO cap, the entire handle AND bell unscrews from the faucet body.
  4. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    it was made after 2009, i bought it last year, just installed it yesterday. how do they come apart then? screws? where?
  5. hj
    Grab the chrome "dome" below the handle and rotate it. CCW to remove, CW to tighten.
  6. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    I'll try it tomorrow. Thanks :)
  7. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    The hot side came off fairly easy, had to use a strap wrench on the cold side. Got it tightened up now. Thanks HJ :)
  8. hj
    BOTH handles should screw on by hand. If it was that tight there is something wrong. Remove both handles and install the hot one on the cold side. If it is still tight, there is a bad thread on the faucet body and it should be exchanged for a new faucet. If the cold handle is tight on the hot side, then the problem is the handle itself and you can call 1-800-BUYMOEN and have them send you a replacement. It should NOT have been loose in the first place, but the bad thread probably did not let the assembler finish tightening it.
  9. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    Thanks, I will try that tomorrow and call moen if it is still tight after swapping handles. :)
Similar Threads: Tightening loose
Plumbing Forum, Professional & DIY Advice American Standard 2 knob faucet cartridge - tightening - valve open or closed? Jul 16, 2016
Plumbing Forum, Professional & DIY Advice Any tips/tricks on tightening flange bolts? Mar 2, 2014
Plumbing Forum, Professional & DIY Advice Tightening dwv test plugs Apr 7, 2013
Plumbing Forum, Professional & DIY Advice about tightening packing nut on old main house shutoff valve Jan 26, 2013
Plumbing Forum, Professional & DIY Advice need help!! - tightening in a confined space Jun 3, 2012
