tighten shower pipe without scratching it ??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hottubbrad, Mar 3, 2009.
  1. hottubbrad
    hottubbrad New Member
    Jun 9, 2008
    What method do you use to tighten the shower pipe into the drop ear elbow...
    I always seem to scratch it with my pipe wrench....
    And the trims don't cover the scratch marks completely.
    ALSO, do you use teflon tape or pipe dope.....
  2. jadnashua
    Use whatever makes you feel better, although many people use both.
    I don't find it a problem to just use the bent arm of the pipe as a lever and just screw it in by hand. They make strap wrenchs that work, and you can insert the handle of say a pair of pliers in the outlet and make a bigger lever. If the pipe is cheap and thin, you can distort it with something in the end, though. Normally, I've not had a problem just doing it by hand, though. Unless the arm is straight, that's normally enough leverage to get it aligned and to seal the connection.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Channey handle in the arm works like a charm!
  5. hj
    idiom
    Now, all the reader has to know is that by "channey" you mean "Channellock pliers" then the answer would make sense to them.
  6. kingsotall
    Aug 17, 2008
    Hey, who're you calling an idiom¿ :cool:
  7. faucetman886
    faucetman886 DIY Junior Member
    Oct 22, 2008
    retired accountant and blogger
    near Atlanta
    I have used an old leather belt or a piece of scrap leather to insolate the pipe wrench from the pipe. If you soak the leather in water it makes it even less likely to do any damage. As the years have gone by and my waist size has grown I always have extra belts..LOL
  8. hj
    belt
    Rosin on the belt, or any other material such as a strap wrench, will let it grip better without slipping.
Similar Threads: tighten shower
Plumbing Forum, Professional & DIY Advice How to tighten a shower head swivel? Jan 7, 2011
Plumbing Forum, Professional & DIY Advice American Standard 2 knob faucet cartridge - tightening - valve open or closed? Jul 16, 2016
Plumbing Forum, Professional & DIY Advice Tighten a handle, Water Ridge kitchen F. 205674 Feb 17, 2015
Plumbing Forum, Professional & DIY Advice is it possible to over-tighten tub drain flange? Sep 1, 2014
Plumbing Forum, Professional & DIY Advice Any tips/tricks on tightening flange bolts? Mar 2, 2014
