tieing into clay sewer line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by little buddy, Jan 13, 2009.
  1. little buddy
    little buddy New Member
    Oct 23, 2007
    Is there a best way to cut into a clay pipe or just bust it out and put the rubber boots in so I can install a clean-out? Is there a standard size clay pipe used from the house to the main? I have dug down to the clay pipe (3.5'), but havn't determined the actual size.The pipe is in about 3' sections and is leaking at both end couplings. The leaking water is not black, it is a dirty brown, nor does it have a terrible, terrible smell. I'm also having trouble figuring out why water is running out of the pipe even when there is no water running in the house. I am having to put a sump pump in the whole to keep up with water pouring out of the pipe.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Have a plumber take a looksey at what you're talking about here. Couldn't hurt, could it¿
  4. hj
    pipe
    It should be 4" clay and the water is coming out because it is either plugged, or it is installed with backwards slope. you cut it with a snap pipe cutter.
    [​IMG]
  5. little buddy
    Oct 23, 2007
    clay pipe
    Thanks for the info. I'm not familiar with snap pipe cutter, but I'm sure I could bye or rent one. Do you supose a guy could take a chizzle and hammer and bust that clay and couple it with a boot to pvs and install a clean-out. Thanks again.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Sorry to say but you have bigger problems if there is water in the pipe.
    It's either clogged or bellied.
    This is a soil pipe cutter AKA Snapper.
    It will easily cut Cast Iron or Vitrified Clay Pipe.
    [​IMG]
Similar Threads: tieing clay
Plumbing Forum, Professional & DIY Advice tieing into 31/2 in cleanout drain plug May 13, 2014
Plumbing Forum, Professional & DIY Advice tieing into cast iron pipe Jan 9, 2009
Plumbing Forum, Professional & DIY Advice Help tieing into 4'' drainage line Oct 8, 2007
Plumbing Forum, Professional & DIY Advice Sewage line cleanout by street - clay?? Sep 16, 2014
Plumbing Forum, Professional & DIY Advice Clay Drain Tile Repair Sep 9, 2014
