*Thud* sound help please
mishelle427
Pennsylvania
Hi
I have read the other posts about a thump sound when toilet flushed but all the answers seem to address the noise happening after a few seconds or after bowl refills etc. My thud happens as you push lever to flush and it's actually louder on the floor below. The bathroom is on the 2nd floor and the thud sound is loud directly under the bathroom which is the kitchen.
This just started happening after I had a new tub/shower combo installed. They had to turn the main water off a few times obviously during this renovation and it started as soon as they were completed. Sadly the plumbing company wants to charge me to come out and take a look saying it is just a coincidence this noise is happening now.
I would appreciate any and all opinions as to what this is and what I can do to stop it. I can live with the noise but I just want to make sure damage isn't being done
Thank you in advance for your time and help!
Michelle
Smooky
North Carolina
What kind of flush mechanism do you have? Is it a pressure assist? Could something be hitting the lid when you flush the toilet? Have you taken the tank lid off and flushed the toilet to try and determine what is happening?
Montreal, Canada
Want to put some effort in taking pics of the whole bathroom, the toilet, and inside the toilet tank?
If not, call your plumbing company. They can't see your toilet either, and they surely won't let you instagram them photos.
mishelle427
Pennsylvania
mishelle427
Pennsylvania
The plumbers just did the work in the bathroom so they are aware of what the toilet looks like. The noise started the day they completed the work and they wont come back out unless they charge even tho their work could've caused it.
mishelle427
Pennsylvania
mishelle427
Pennsylvania
Smooky
North Carolina
If the thud happens at the end of the fill cycle you may need a new fill valve. If the plumber fixed some leaky faucets that might have caused the toilet thud to be more pronounced but it is a separate issue.
Montreal, Canada
Yes but your same plumbers won't be here on the internet helping you out. You're reaching out to strangers that have no idea what work was done, no idea what your bathroom layout is like, and no idea what is inside your toilet.
#9 can be right. I also see a lot of external pipes that can be loose and prone to hammering. I'd touch them in various spots and see if you can feel the thuds.
That may be true, but plumbers like to get paid for time and travel, so you might want to keep that in mind that they are being reasonable.
mishelle427
Pennsylvania
The thud happens as I flush and is more pronounced in the floor below. Right under bathroom. The plumbers installed a tub/shower combo. I think it has something to do with the main valve being turned on and off. The water pressure seems stronger now
mishelle427
Pennsylvania
Yes. You're right. This is all new to me. Reaching out on a forum to strangers but everyone on here seemed helpful and informative. Good idea to touch pipe to feel thud. Should I try turning toilet valve off and on or turn valve off slightly. I've also read on here to turn main valve off and open all faucets and flush. What are your thoughts?
Smooky
North Carolina
Sometimes in older homes, air chambers were installed in the water pipes. They work line hammer aresters but not as good. Over time they can get water logged or they may have been removed if some plumbing was replaced. It will not hurt anything to shut off the main water supply and go around and open all your faucets to try and drain all the water out of pipes both hot and cold. If you do that, shut off the hot water heater until you turn the water back on and let the air back out. If there are air chambers, air will stay in them. It may or may not help.
Here is an add on hammer arrester for a toilet:
https://hdsupplysolutions.com/shop/...sion-p569305?gclid=COTwg87a2MwCFdgMgQodRYkDcg
I would replace the fill valve before doing anything else.
You have a little valve at the wall that feeds water to the toilet tank. I would close that valve (turn off the water). Do a flush. Does the noise you describe happen in that case?
Turn the valve back on, and let us know what you learned.
WJcandee
Wise One
New York, NY
RIght. If you get the thud with the water turned OFF at the wall, it's probably not water hammer and not anything to do with your water pipes, but rather something with the toilet or drain. If you don't get the thud with the water off at the wall, then that means something else. As Reach says, let us know that.
Turning the water on and off at the main is a standard procedure. Most likely, it has happened before and probably not in and of itself the cause of your problem. But let us know the answers to the questions.
mishelle427
Pennsylvania
Keep reproducing the thud sound with your toilet as you have your hands and bare feet touch as many things as you can. The pipes. The base of the toilet. The toilet tank. Wall. Floor. Anything. The longer you diagnose, the closer you will get to it.
Good suggestions. Thank you. I felt the pipes that are by the toilet and I can feel the vibration in them but not sure if that's normal function.
mishelle427
Pennsylvania
Thank you for the info and advice
mishelle427
Pennsylvania
I'm kind of afraid to do this. I don't want to make things worse. But I will try it. Sounds like I should
mishelle427
Pennsylvania
That makes sense too. The main probably has been turned off and this hasn't happened. I've had so many things done in the last 2 years. Sump pump, basement waterproofed, electric upgraded, new windows, new furnace, central air installed and now new bath/shower installed. Always something when you own an old house!
