Hi
I have three poor producing wells, each around 400 feet, together they give me enough water but I have them on a combination of timers and 3 pressure switches, set at different cut ins and offs. This works but often I have to manually shut off one to give it time to recover, however I will be renting the house so want to make it as easy as possible now..
I was thinking of doing away with two pressure switches and running them all through one pressure switch so that they all turn on and off at the same time. Each one would still be on a pumptec or cycle sensor, so if it did run dry would stop forcing the pump.
Can you see any problems with doing this?
thanks in advance
Warren
thanks in advance
Warren
