philly
Hello!
I'm renovating an 1850's Philadelphia rowhouse with one bath. After looking through the big box offerings I couldn't find anything which fit the look I was going for. After more searching, I splurged on a very nice three handle diverter set from Strom (or Sign of the Crab). The diverter actually ships in pieces, where the hot, cold, and diverter valves are all separate and must be connected by supplied brass nipples.
I assembled the valves and diverters following the stampings on the valves (Hot supply valve connected to the H on the diverter, C to C). This leaves the T (for Tub I assume) connection on the diverter facing down and the S (for Shower) facing up. Before installing the diverter I pressure tested it to check for any leaks, and found that turning both the hot and cold valves clockwise shuts turns the water off. However turning the diverter clockwise diverts water to the showerhead, rather than the tub spigot, which seems counterintuitive. Is there any way to reverse the operation of this valve? Can I install the diverter body upside down? When I look in the diverter outlets for the shower and tub connections, I see one hole in the shower outlet, and two in the tub outlet, so I'm not sure the valve is the same if installed upside down. I tried contacting Strom, but they are off for the holiday and I was hoping to get this installed this weekend.
For reference the valve set is the St Lawrence series from Strom/Sign of the Crab (P0352). Thanks in advance for any insight!
