Threadless coupling for galvanized pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brother, Dec 16, 2009.
  1. brother
    brother Member
    Dec 9, 2007
    UPC
    Do they make a threadless coupling for galvanized pipe?? I had a situation where we had to cut the pipe, but no threads. and it would be WHOLE lot easier to just couple it on there, without haveing to go all the way back to the thread. This is in concrete by way.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If it's drain or vent you can use a mission coupling.
  4. hj
    pipe
    They make them, but I would NEVER use one if it is going to covered with concrete, if it is a water pipe. Drain lines have a few threadless options.
  5. dlh
    dlh plumbing consultant
    Aug 14, 2009
    plumbing consultant
    dallas texas
    you might be able to use a brass compression coupling but i would not install it under concrete.
    why not just make new threads on the pipe? i do that when the customer doesnt want the cost of a complete new line. you should be able to rent a die and handle
  6. brother
    brother Member
    Dec 9, 2007
    UPC
    this is not a drain, its for a water supply line, that would be under water pressure. Now about not threading it again, this is in concrete we had to jack hammer out. Theres not much room to thread unless wwe jack hammer more. Thats a alot, and I want to avoid that if I can, and just repair it there.
  7. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    There are "dresser couplings" make specifically for pressure pipe and It can be used underground.
    Google "dresser coupling", I know they are available in Canada, but not very sure where it might be available in the US
    Its like an oversized compression coupling using rubber rings instead of brass rings
  8. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Heh I opened this thread just to bring up these couplings! I have used them before I would have no trouble using them again in a pinch.
    As long as you can make a good seal on the old pipe you'll be just fine.
  9. brother
    brother Member
    Dec 9, 2007
    UPC
    Is this what your talking about??
    http://hubpages.com/hub/HowToRepairaPipeUsingDresserCouplings
  10. Cass
    Cass Plumber
    Nov 12, 2005
    Do not use the ones sold at the big box stores...they will rust out in a year or so...they sell dresser couplings at supply houses that meet code requirements...
Similar Threads: Threadless coupling
Plumbing Forum, Professional & DIY Advice Capping a threadless pipe May 19, 2009
Plumbing Forum, Professional & DIY Advice Maximum gap for coupling two DWV pipes Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Copper pipe too short to attach a coupling and extension? Sep 10, 2016
Plumbing Forum, Professional & DIY Advice Galvanized compression coupling Aug 1, 2016
Plumbing Forum, Professional & DIY Advice 3" Mission No Hub Coupling Appropriate? May 26, 2016
