threading PVC fitting into cast iron stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ksudar, Jul 21, 2010.
  1. ksudar
    ksudar New Member
    Jul 21, 2010
    northern va
    Hello.. I'm redoing a bathroom and have to replace a section of 1-1/2" galvanized drain pipe, which runs horizontally before it meets the main cast iron stack. Now, I was able to remove all of the galvanized pipe and found a 1-1/2" PVC threaded male coupling that will thread into the cast iron hub. My question is whether this will work, and if so what type of sealant I should use on the threads? Thanks for the help-
  2. jc60618
    jc60618 DIY Junior Member
    Dec 12, 2009
    Apprentice Plumber
    Chicago
    I use teflon tape and Megalock pipe dope. I also would use a PVC schedule 80 male adapter instead of the regular one.
  4. ksudar
    ksudar New Member
    Jul 21, 2010
    northern va
    thanks for the help... I'll give the pipe dope a try and see if it holds.
  5. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    What you have will work, I only use pipe compound on them, make sure you clean the metal threads and don't cross- thread it.
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    I would use a male adapter on a drain rather than a sch 80 nipple. The nipple reduces the ID of the pipe, creating a place for things to start to clog
  7. ksudar
    ksudar New Member
    Jul 21, 2010
    northern va
    This is what I used - I did look for the sch. 80 fitting but they only carried 1-1/4" and smaller. Luckily the cast iron threads were still in pretty good shape, even though the galvanized piece had rusted out. And I'm pretty sure the old pipe was sloping in the wrong direction too. :rolleyes:
  8. Fireguy97
    Fireguy97 Irrigation Contractor
    Mar 21, 2010
    Irrigation Contractor / Certified Backflow Assembl
    Kamloops, in Beautiful British Col
    The "Rules" of PVC, according to the manufacturers.
    (From another forum, courtesy of TreeMonkey)
    Apollo Company strongly recommends not using plastic piping with metallic ball valves, 4th paragraph down:
    http://www.apollovalves.com/_docs/CautionPage.pdf
    Spears (and more so, Lasco) strongly suggest that you only use sealant, not tape, on threaded PVC fittings. The Lasco link to follow goes in to great detail.
    http://www.spearsmfg.com/how_to/FG-3B-0105_0706_English.pdf
    And finally, Lasco has all kinds of rules about using threaded PVC: Sch. 80 not to be mixed with sch 40, absolutely no tape, etc., with a lengthy explanation of the engineering principles behind it. http://www.lascofittings.com/supportcenter/TheDosandDontsThreadedPlastic.asp
    http://www.lascofittings.com/supportcenter/ThreadedPlastic.asp
    http://www.lascofittings.com/supportcenter/Schedule40threads.asp
    The Lasco site has several more links to info about threaded PVC such as this one:
    Why PVC Threaded Connections Fail:
    http://www.lascofittings.com/supportcenter/WhyThreadedConnectionsFail.asp
    Mick
Similar Threads: threading fitting
Plumbing Forum, Professional & DIY Advice Threading pipe Dec 3, 2015
Plumbing Forum, Professional & DIY Advice Woodford (model 14?) nozzle threading Jun 3, 2014
Plumbing Forum, Professional & DIY Advice Plumbing the Hard Way - Threading on Exisiting Risers May 20, 2013
Plumbing Forum, Professional & DIY Advice pipe threading tool Mar 14, 2011
Plumbing Forum, Professional & DIY Advice Corroded threading help Aug 8, 2009
