Threaded PVC Fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bf9ys02, Oct 21, 2005.
  1. bf9ys02
    bf9ys02 New Member
    Oct 21, 2005
    I replaced galvanized nipples at toilet and cold lavatory supply valves with gray PVC nipples. What would be wrong with using them for the hot supplies as well?
  2. hj
    nipples
    OTher than the fact that they can, and often will, crack at the threads, even on the cold water side, and that the hot water will soften them, I guess nothing. It is your house and you can flood it if you want to.
  4. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    Are these a pvc nipple or a nylon nipple? If grey pvc then are they SCH 80? Please explain whey these nipples will crack and break. This is something i was unaware of.
    thanks.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    PVC is not allowed within a dwelling by any code. Plastic nipples do have a tendency to crack at the root of the threads. In CPVC work, I do not know if nipples are used. I would prefer a glued stub-out.
  6. bf9ys02
    bf9ys02 New Member
    Oct 21, 2005
    For what it is worth, they are SCHD 80. Sounds like a bad idea though.
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    plastic
    For sure....
  8. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    PVC is weak when hot; therefore not suitable for hot water even where permitted by code. CPVC is ok for hot water but may be expensive.
  9. rshackleford
    Oct 18, 2005
    Is there somthing other than hot water in homes that makes PVC a particularily bad choice? What makes PVC fail at the threads? Does the size or sch of PVC make a difference?
  10. jimbo
    jimbo Plumber
    San Diego, CA
    What makes PVC fail at the threads? :::: It's plastic for gosh sake!
    Does the size or sch of PVC make a difference? ::::: size always matters.
  11. hj
    pvc
    I have seen every size of PVC break at the threads. It is a rigid material that has absolutely no tolerance for lateral stress. Especially after a lot of material is removed to thread it. If you move/bend the PVC sideways at a thread it will crack.
  12. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    How about useing brass nipples. Install today and they'll be good as new when all of us are worm food.
  13. rshackleford
    Oct 18, 2005
    Are we talking pressure PVC or dwv?
    I have seen municipal pump houses, well pits, stock water pipelines, and other work done with all PVC fittings. I will concede that often when the pipe is four, maybe three, inches or larger flanges are often use; however small pipes are pretty much put together with threaded pvc. I do notice that many buried PVC fittings in engineered jobs are pack joint type fittings. Also, pvc water well drop pipe is threaded pvc, but that doesn't have lateral stress.
    Is there more movement in a household plumbing that causes the threads to fail? Is there something else?
    This is all really interesting. Thanks for the information.
  14. Gary Slusser
    Retired
    I think it's LASCO that says the primary cause of PVC and other plastic females failing is overtightening them; in essence, not following the instructions.
    I've used many of all types over many years without failure. I also use plastic males with the same results.
    Gary
    Quality Water Associates
Similar Threads: Threaded Fittings
Plumbing Forum, Professional & DIY Advice Threaded brass fittings ok in baseboard heating system? Jun 7, 2013
Plumbing Forum, Professional & DIY Advice soldering threaded fittings Nov 2, 2010
Plumbing Forum, Professional & DIY Advice Plastic to plastic threaded fittings... use teflon or not? Aug 7, 2010
Plumbing Forum, Professional & DIY Advice How tightly should [Gator|Shark]bite fittings be screwed to threaded brass? Nov 9, 2009
Plumbing Forum, Professional & DIY Advice Threaded PVC fittings Mar 28, 2009
