Lithnights
Mikey said:I guess "most" answers the question of how you screwed in the adapters with the joints soldered? I use both Teflon tape and a wicked blue goo that gets all over everything. Just finished re-plumbing overhead after finding under-slab leaks, pressure-tested everything at 100psi and no pressure drop. (Actually saw a slight rise in the afternoon, which I blamed on the attic getting hot.) Seems to be holding water at 60 psi OK. Wife loves having hot water at the sink again. Life is good.
Only problem I've had with the adapters you illustrated is their QC is terrible as far as the size of the hexes goes. Won't matter if you use an adjustable wrench on them, but in one situation I had to use a deep socket and had a lot of trouble. Wound up taking a socket to HD and matching up 9 adapters to the socket. You'd have the same problem with a fixed open-end wrench.
You are correct. "Most" meant as many as I could do without leaving me no ability to tighten up the threaded adapters.
I guess I still wonder why companies make these diverters that have adapter inputs only. One is forced to use a threaded adapter instead of a sweat. I'd rather see everything be able to be sweated.
