threaded fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by oops, Jun 27, 2005.
  1. oops
    oops New Member
    Jun 27, 2005
    Hello '
    Here's a problem thats been vexing us for a couple years.installed new pressure tank threaded fittings become loose after awhile how can this happen?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Vibration is most likely the reason. What type of fittings? Material?
  4. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    Yes, sounds like vibration, and as rugged asked, what materials are involved? Most likely the pressure tank is steel with a female threaded fitting to connect to the plumbing system.
    This time when you re-plumb the tank, make sure all fittings and threads are dry, use a quality pipe thread compound and allow it to fully cure prior to pressurizing the system.
Similar Threads: threaded fittings
Plumbing Forum, Professional & DIY Advice Threaded brass fittings ok in baseboard heating system? Jun 7, 2013
Plumbing Forum, Professional & DIY Advice soldering threaded fittings Nov 2, 2010
Plumbing Forum, Professional & DIY Advice Plastic to plastic threaded fittings... use teflon or not? Aug 7, 2010
Plumbing Forum, Professional & DIY Advice How tightly should [Gator|Shark]bite fittings be screwed to threaded brass? Nov 9, 2009
Plumbing Forum, Professional & DIY Advice Threaded PVC fittings Mar 28, 2009
