Thinset Thickness
Discussion in 'Shower & Bathtub Forum & Blog' started by cjt, Nov 1, 2007.
  1. cjt
    cjt New Member
    Jul 13, 2006
    Hi,
    I have installed cement board surrounding the tub/shower alcove and am in the process of using thinset to cover joints. I have a small area that need some levelling and am wondering how thick I can go with the thinset to even out the inconsistenices. Any thoughts?
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I believe you can build it up as much as you want or need as long as you do it a little at a time ... like about 1/4" or so.
  4. jadnashua
    Hopefully, you're using the special alkalai resistant mesh tape on those joints. It is ususally easier to tape them when tiling, otherwise it is likely you'll end up with a hump. Finishing cbu in prep for tile is not like doing drywall, it doesn't have to look pretty. Most thinsets can go up to 1/4" in one app. A medium bed mortar (often called granite and marble mortar) can go up to around 1" or so, depends on the brand. Also, while it is very important to get full coverage when tiling a floor, one technique that can be used for walls is the 'spot' method. Bascially, depending on the size of the tile, you back butter it, then put big dabs of thinset in 'dots' symmetrically on it...then smush it on the wall until it is lined up where you want.
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Thin-set Thickness = 1/4" for most 1" for a few
  6. jadnashua
    ANSI A118.3 defines the spot method of setting tile, and is an approved method. It is not applicable with some tile (such as transparent, translucent, or those subject to variations in color based on moisture), but is viable with many tile. It's still better to get your setting surface flat and true before you try to set the tile.
    And, John Whipple is saying the same thing about max depth of mortar as I. He just likes to throw more darts.
    Thinset isn't really designed as a surface filler/flattening material - using it as such might lead to problems. A medium bed mortar, as long as the max thickness does not exceed the manufacturer's recommendation, should work without issues, though.
Similar Threads: Thinset Thickness
Shower & Bathtub Forum & Blog Dried thinset on tile surface Jan 2, 2016
Shower & Bathtub Forum & Blog What Is the Best Porcelain Tile Thinset Mortar? Apr 18, 2015
Shower & Bathtub Forum & Blog Mixing thinset and cleaning the paddle with ease Nov 21, 2014
Shower & Bathtub Forum & Blog Thinset (thin-set) : Changing Water Ratio's that are spec'd by manufacture Oct 19, 2014
Shower & Bathtub Forum & Blog Thinset and Schluter Membranes Mar 18, 2014
