Think I screwed up
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by apriorius, Jul 11, 2008.
  1. apriorius
    apriorius New Member
    Jul 11, 2008
    I plumbed in a garbage disposal and faucet set into my new granite counters today after waiting a day for the silicone to seal. The faucet and knob had rubber washers underneath, but the sprayer and soap pump had nothing. Following the instructions, I used a bead of plumbers putty underneath each. Now I'm reading that the putty can discolor granite. Will such a small application cause problems? If so, and I pull it immediately and replace it with clear silicone, will I be allright, or am I already screwed? :(
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    If you do it ASAP youwill be okay!
    Hercules Sta-Put Ultra Plumbers Putty can also be used it is Non-Staining
    Use that or Silicone RTV
    [​IMG]
  4. apriorius
    Jul 11, 2008
    EDIT: Thanks Redwood...I was posting while you did, so I missed it. Already pulled them since I figured better safe than sorry. Glad I did!
    Well, I figured the best thing to do was pull the items in question.
    HOLY CRAP
    The putty had already started to take the color of the stone! I wiped off the countertops and the rag was coming up stained the same color as the counters over the small area of contamination. These fixtures have been in place about eight hours tops.
    I got all the puttey off with an old toothbrush, sprayed the heck out of it with 409 cleaner, and wiped the entire counter down with soapy water. Now I'm a little paranoid to even put these back in with silicone until I can figure out what will cut through any residue the putty left behind.
    Man, I hope I caught this in time and there's no discoloration. Thanks for the great instructions, Kohler! :mad::mad: I supposed stained granite is BOLD, huh?
  5. apriorius
    Jul 11, 2008
    Check it out...page five:
    http://www.us.kohler.com/onlinecatalog/pdf/1084448_2.pdf
    Unbelieveable they would not mention the dangerous interaction between granite and plumbers putty, especially on a friggin $250 faucet set.
    I'm not sue happy in any way, but I would have marched straight to small claims with this one.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Yea the oil from the putty soaks in... You should be fine!
    This type is what I use and is safe for porous materials.
    [​IMG]
  7. apriorius
    Jul 11, 2008
    Thanks again...I already have some clear GE silicone II kicking around, so I'll use it instead of making another trip to the borg. Also gonna try and dig up some rubbing alcohol tonight and give it another wipedown. I am so pleased with these counters I'll be *really* upset if eight hours was enough time to leech oil to the point of staining.
Similar Threads: screwed
Plumbing Forum, Professional & DIY Advice Can't get faucet cartridge unscrewed Sep 3, 2015
Plumbing Forum, Professional & DIY Advice Countertop guys screwed up sink install! May 16, 2015
Plumbing Forum, Professional & DIY Advice I screwed up, tiled my floor too tight for the closet flange to sit flush Dec 11, 2013
Plumbing Forum, Professional & DIY Advice Help! I screwed up. Deep sink with disposer Dec 6, 2012
Plumbing Forum, Professional & DIY Advice I can't get this p-trap unscrewed. Oct 23, 2012
