Thick Deck Extension Kit for 1" Straight Threaded Shanks?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sethamin, May 1, 2014.
  1. sethamin
    sethamin New Member
    Feb 21, 2013
    Brooklyn, NY, United States
    We bought a widespread faucet for our new bathroom vanity - unfortunately, the max deck thickness is a 1-5/8", and the countertop is 2" thick. I called the retailer but there's no deck extension kit for this faucet. Is there a deck extension kit from another manufacturer that would work here? The faucet has 1" shanks with straight threading. The spout has a valve that screws on to the end of the shank, so the extension would need to have a hose-style compression fitting on the end to get a sealed connection. The drilled holes in the deck are 1-1/8", so the extension would need to fit inside that.
    Any ideas?
    (Other than "buy a better brand of faucet with a deck extension kit")
  2. hj
    The kits would be "brand specific" so unless that faucet was made by a major manufacturer and rebranded, you are probably out of luck, unless you can "recess" the mounting.
  4. sethamin
    sethamin New Member
    Feb 21, 2013
    The countertop is marble, so I probably could "recess" the mounting by countersinking the underside of the faucet hole with my dremel. But I'd have to notch at least 1/2" out, and the countertop is already installed so it'd be awkward. And I'd have to do that for 3 separate holes. That doesn't sound like much fun.
  5. hj
    The marble does not have a 3/4" plywood base under it? That would be unusual.
  6. Terry
    Aug 17, 2004
    I would guess that the marble has plywood under it.
    You will need to use a hole saw and make larger holes in the wood. You can place a 2x4 over the top, and drill into that for the pilot. The marble setter should have cut the plywood out for the faucet first. But they don't always. It's a nasty job cutting the wood out after the fact.
  7. sethamin
    sethamin New Member
    Feb 21, 2013
    There's no plywood underneath the marble. Perhaps that's because it has an undermount sink which sits in a "bracket" that's attached the cabinet base.
Similar Threads: Thick Deck
Plumbing Forum, Professional & DIY Advice 1922 boiler pipe thickness Sep 29, 2016
Plumbing Forum, Professional & DIY Advice Rough Plumbing Strategy, Thickened Slab Jul 29, 2016
Plumbing Forum, Professional & DIY Advice Vanity Top Too Thick to Mount Sink? Dec 5, 2009
Plumbing Forum, Professional & DIY Advice Need help installing Toto using extra thick wax ring Dec 30, 2008
Plumbing Forum, Professional & DIY Advice Faucet fittings too short - thick countertop Aug 18, 2005
