These aren't shutoff valves! what are they?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by red_lover, Mar 5, 2011.
  1. red_lover
    red_lover New Member
    Oct 7, 2004
    Oregon
    I went under the sink to turn off the water supply and found these plastic-like connections that have a disk that I thought might be the shutoff but they just seem to freewheel forever. does anyone know what they are?
    [​IMG]
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    Yeah, they're shut off valves, el cheapo ones. You have to either pull or push the disk (in or out, I forget which) to shut them off or turn them on.
  4. red_lover
    Oct 7, 2004
    Oregon
    REALLY? WOW I have never seen any like this! I guess I will try pulling first LOL. Thank you so much for your response Furd. You learn something new every day, especially when you buy a new house!
  5. Furd
    Furd Engineer
    Jul 3, 2007
    If you get up real close it is spelled out on the disk to push or pull. I didn't know myself until about a month ago when my sister bought a new (to her) house and it has those funky valves only hers have the hose permanently fastened.
  6. jimbo
    jimbo Plumber
    San Diego, CA
  7. hj
    Your real fun will come when you have to replace those valves since they slide on easily, but do NOT like to slide off. I cannot imagine putting a metal compression nut on a plastic valve the way those seem to be assembled. I remove and replace a lot of those valves, but have NEVER installed one, nor would I.
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Yep and be gentle when you do shut hem off, they have a nasty habit of snapping off at the wall.
  9. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    That doesn't make sense. There is copper coming from the wall...
  10. jimbo
    jimbo Plumber
    San Diego, CA
    The removal procedure is to PULL HARD AND TWIST.. they come off in about two full revolutions. There is no compression nut involved. They just push on like a shark. The do have a recess to allow you to leave the existing ferrule on...it just gets hidden in the shroud. And they recommend "burying" the original nut into the the drywall, and include a flat escutcheon to hide that.
  11. hj
    I KNOW how to remove them. IT is the homeowner who will have a problem doing it.
  12. Wendy Hornyak Stanziano
    Wendy Hornyak Stanziano New Member
    Jul 9, 2011
    Florida
    I have these stupid things too...HELP!
    Ok, so I have these under the kitchen sink. Replacing the faucet from a 2 handle to a 1 handle. The new faucet comes with supply lines and compression fittings that go directly to the hot and cold...except my plastic "knobs" already have supply lines coming from them. (Not the compression type.) Do these come off? What do I do now (besides call in a plumber!!)?
  13. jadnashua
    Yes, the do come off (they are pushed on). Not sure how they release, if they do. You may need to cut them off. One of the pros will know. This has been discussed before: you may find it with the search function. If the gripper teeth score the pipe too much, you may only get a good seal if you solder on a new one.
  14. Wendy Hornyak Stanziano
    Jul 9, 2011
    Florida
    I'm sorry, I meant do the SUPPLY lines come off? I really don't want to replace the whole shut off unless ABSOLUTELY needed.
  15. Terry
    Aug 17, 2004
    The ends of you supply line are 1/2" female. Pick up a 3/8" compression x 1/2" brass adapter.
    The small 3/8" side will work on the new faucet supplies and the 1/2" end will thread to the existing supply lines.
  16. jadnashua
    Those valves I've heard, can get brittle and crack as they get old...it's not a bad idea to get rid of them. Your results may differ...
  17. ballvalve
    Dec 28, 2009
    northfork, california
    I have some of those seemingly cheap valves for 30 years in a house, without any issues. I know disasters happen fast, but they happen to the hoses even more often.
    Has anyone had to go to a house where these valves exploded? They were US made and perhaps they used a good plastic with good quality control.
    I think you could call these the original sharkbite concept.
  18. daddybill13
    daddybill13 New Member
    Nov 1, 2012
    What are they called so I can look them up anmd find out how to remove them properly and install decent shut offs?
  19. chessie
    chessie New Member
    Oct 31, 2012
    Virginia
    Someone posted a link to the site, in a post up above. You shuold be able to find more info there.
    http://www.accortechnology.com/
  20. jjosserand
    jjosserand New Member
    Jan 17, 2014
    Washington
    Those are the pull to close type
    Should be written on the disk, but they pull to close.
  21. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Best thing to do with them is to cut the off and put on some 1/4 turn metal valves.
Similar Threads: aren't shutoff
Plumbing Forum, Professional & DIY Advice Galvanic Corrosion when pipes aren't in contact Jan 26, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Sink Remodel/Drain Pieces Aren't Long Enough Nov 7, 2006
Plumbing Forum, Professional & DIY Advice Need help with Pump Pressure switch shutoff Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Shutoff Valve Won't Open Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Finding Replacement Shutoff Valve Handle Nov 13, 2016
