Thermostats : Dual Element in a Single Element Water Heater
Discussion in 'Water Heater Forum, Tanks' started by Synicasm, Nov 5, 2009.
  1. Synicasm
    Synicasm New Member
    Nov 5, 2009
    Oregon
    Is it ok to use a Dual Element Thermostat on a Single Element Water heater by just not hooking anything up to the "lower thermostat" connections ?
  2. WorthFlorida
    WorthFlorida USCG escorting cruise ship leaving Port Everglades
    Oct 28, 2009
    Retired
    Orlando, Florida
    Why do you think you need a new thermostat? Always change parts with the right/correct part.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I would use the upper thermostat. If you use the lower you will have no protection for over heating.
    John
    PS woethflorida I didn't see that you changed your post recommending using the lower element.
  5. hj
    thermostat
    Find a "solar water heater" themostat. It is for a single element and has the required ECO, but is less expensive than the SPDT upper thermostat. But otherwise, it is okay to use the upper one as long as you connect the element to the "upper element" terminals.
  6. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    At first I did say a lower thermostat but then I realized that it does not have a built in circuit breaker. I "edited" my first comment.
Similar Threads: Thermostats Dual
Water Heater Forum, Tanks Wiring requirements for 4500W dual-element May 25, 2015
Water Heater Forum, Tanks Dual Water Heaters & legionnaires disease Jan 22, 2015
Water Heater Forum, Tanks What's better than a Bradford White dual outlet (radiant and domestic) gas heater? Jun 13, 2014
Water Heater Forum, Tanks Electric tank with dual watt lower element Oct 29, 2013
Water Heater Forum, Tanks Dual AO Smith 50 gal Vented Gas Installation - Options? Dec 2, 2011
