thermostatic valve calibration...
Discussion in 'Shower & Bathtub Forum & Blog' started by chris fox, May 20, 2007.
  1. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    I finished up my soldering the valves in my shower. I checked for leaks by turning on/off the knurled brass stems for both flow and thermostat.
    I just read the instructions for this Danze valve kit and cautions against adjusting the thermostat BEFORE the mixing valve assembly which is in the trim kit. Apparently its already calibrated. Is this a big deal, I understand the whole scalding warning etc.
    If I want to get this back to factory specs, is there a way to reset this without using a thermometer in the water to match to the mixing knob?
    thanks..
    chris
  2. jadnashua
    Probably not...adjust it once you get the water running.
Similar Threads: thermostatic valve
Shower & Bathtub Forum & Blog Kohler DTV Thermostatic Valve Systems Aug 31, 2015
Shower & Bathtub Forum & Blog Hudson reed thermostatic shower valve Aug 27, 2015
Shower & Bathtub Forum & Blog Kohler 3/4" Thermostatic Mixer Valve K2976 (stacked) Jul 30, 2015
Shower & Bathtub Forum & Blog Thermostatic mixing valve - hot water only? May 26, 2015
Shower & Bathtub Forum & Blog Grohe Thermostatic shower valve issue Dec 23, 2013
